Tractor Talk Discussion Forum
WHAT will we do
No tools
11-15-2006 03:51:47
Well little nicer this morning 41 degrees.
well got all the machines running again last night.
Looks like it's going to be a busy day for them.Have a good safe day boys.
BILL
Satsop
11-15-2006 09:27:01
 Re: WHAT will we do in reply to No tools, 11-15-2006 03:51:47
Going to the fair grounds to do vol. work. Our clubs show chairman will meet with myself and the fair manager to discus next yr's show.
Then off to Olympia with the boss to see my lung Doctor at 4:15, I havent been able to sleep w/o getting up after a few hours and using a nebuliser. If it aint the shoulders its the lungs.
48* here this morning. Weatherman predicted high winds overnite. Didn't get them so they must have meant high altitude.
Jim
730virgil
11-15-2006 08:39:39
36 at 10:30 am looks like sun might make it out . neighbor and hired man went by about 9 with 2 combines he farms quite a bit and does some custom work too . still a fair amount of corn in feilds for this time of nov. wet oct put everyone behind . about this time of year most guys are getting tired of mud and ready for things to freeze .
then we get into different set of headaches .
Aaron Ford
11-15-2006 07:33:57
Got out of Calculus at 9:30, now I am going to set up to install my rear seals prior to picking the boy up from preschool. Daughter is at storytime at the local library. Might change some oil today...
Here are the stinkers....
third party image
Back to work tomorrow...
No tools
11-15-2006 12:44:33
 Re: WHAT will we do in reply to Aaron Ford, 11-15-2006 07:33:57
BEAUTIFUL CHILDREN there Aaron Ford.
Wish mine were that small again.
No grand babys yet?
IBorange in TX
11-15-2006 08:25:44
Good looking kids.....must have a beautiful mother!!!!
Good Luck..... .
Aaron Ford
11-15-2006 12:12:19
 Re: WHAT will we do in reply to IBorange in TX, 11-15-2006 08:25:44
Howdya guess? LOL Aaron
the tractor vet
11-15-2006 06:26:12
Work on this OLD HOUSE as this job is dragging on and on and all ya get done is tryen to make things work out . Good thing that the guy that Built this OLD DUMP is LONG DEAD AND GONE as he and i would have some seirous issues over his building methiods and his one TOOL would turn up missing and maybe his main TOOL also as i would use it to remove his other , His hatchit . And all them Yuppy's that just love OLD houses THEY ARE PLUM OUT OF THERE MINDS . Should have realy went with my GUT instink and went with 5 gallons of diesel and match on this one . Hoppen that in a couple more hours i am done with my office and can move on to the living room . I was realy hoppen to be done with all the downsairs before turkey day BUT THAT AIN'T GOING TO HAPPEN.
No tools
11-15-2006 06:19:27
well 9:15 and it is pouring down rain.
that will be hard on the old equipment manifolds today.
BILL.
billonthefarm
11-15-2006 05:48:10
Another rainy windy day. Maybe if it doesnt rain the 30 mph gust will help it dry. I should be able to finish up repairs on the corn sheller today. Need to get the disk in the shop between showers and have a look at a hinge pin that has moved. Will run over and pick up a harrow spring for the chisel that should be in. After that it will be hard to say. Really need to tear into a leak in the powersteering on the 830 or pull the hydraulic pump out of the 4010. I've got to get to town and see my brother in law and get another machine shed ordered so I can get started building it sooner than later. bill
BigMarv1085
11-15-2006 05:19:34
Iv'e got to change out a set of dual wheel tires on neighbors 8600. Hope I don't pinch a tube and hope that the tires don't have any liquid ballast.
williamf
11-15-2006 05:14:46
 Re: WHAT will we do - a long read in reply to No tools, 11-15-2006 03:51:47
It'll rain this evening here, too. So this morning I'll go down in the swamp to finish the little bit of road work I was on Monday when the hydraulic line sprung a leak. Which covers what I did yesterday. And Monday.
It's the second time I've replaced that hose, and the one next to it that goes to the other end of the same cylinder twice also. After I replaced the other the second time I admitted that I understood some things better than the designers and didn't put it back in the clamp. Engineers hate to see a hydraulic hose move along its length but sometimes that's better than having it crimp and twist where it's held tight.
If I had gone back and liberated this one at the same time I would have had to find something else to keep myself busy today.
It's a serious chore to replace one of these; this one required taking the seat off and taking loose six other hoses to get to the end up under the platform. All of them hard to reach. Put the wrench on, turn the tiniest fraction, take the wrench out, move around to the other side of the tractor, climb up and twist around to reach, insert the wrench though another hole, turn another tiny fraction, climb back down, go back to the first hole and insert a different wrench, another miniscule movement.... The only thing that kept me going was knowing I had done it before so it had to be possible. I was younger then, though.
It took eight hours actual work time and two trips to town. The bright spots: I replaced the ends on two of the really difficult hoses - they were male ends that required turning the whole hose to unscrew them. With to 90* turns in the hose that's a job for three hands.
Also, by chance I wore a t-shirt from the mill where I work to the hydraulic service place. Turns out the counter guy did a lot of business with the maintenence folks in my department, we knew a lot of the same people, when he wrote up my bill he gave me the same discount IP gets. Bill was half what I expected.
It's who you know.
Better day today and much needed rain tonight.
Wm
jddriver
11-15-2006 05:11:28
P.T. at 730 then home to do awater pump and spark plugs and wires on the caprice flat rate is a bit over 8 hours pob take me 12.42 here and 25 mph wind going to 31 and windt
MH
11-15-2006 04:14:54
Well, supposed to start raining this evening here in central NC, guess after the day job I'm going to mess with putting new bucket cylinders on the loader tractor.
Matthew
IaGary
11-15-2006 04:13:47
Weather is still cool and soupy here.
Got the room done so now back to farmin.
Need to put new points on the chisel plow.
And maybe if the cows cooperate I will wean calves today.
Gary
WyoDave
11-15-2006 04:11:48
Feed the calves in the lot, then head out to check cows/waterers on winter pasture. After that the day is wide open. I have plenty to keep busy, just not sure what I want to do.
David
Nebraska Cowman
11-15-2006 04:00:33
It is a little cool here but the wind has gone down. I'm going to move about 75 of the working girls into a field. That and monkey with my Ask Cowman wbb site. Guys are having trouble registering and I think it is mostly because they are used to having spaces in their user names. letters and numbers only, no punctuation or spaces. That's my day :)
third party image
kyhayman
11-15-2006 05:46:16
 Re: WHAT will we do in reply to Nebraska Cowman, 11-15-2006 04:00:33
Neat site, I'd love to chat software with you sometime.
Nebraska Cowman
11-15-2006 05:53:08
 Re: WHAT will we do in reply to kyhayman, 11-15-2006 05:46:16
I didn't do a thing. The software is at their end. (proboards) At some point I want to host my own but that is going to be down the road a ways.
No tools
11-15-2006 03:54:27
Sorry on the double post thought i lost the first????? ?>
BillD1
11-15-2006 05:21:52
 Re: WHAT will we do in reply to No tools, 11-15-2006 03:54:27
Need to run a few errands while the shop is warming up Then its open season on a couple of small wood working jobs that have been laying around much to long. am ready to start fitting the fenders and floor boards to the WD-40 so that the fenders can be drilled and preped for paint.
