Tractor Talk Discussion Forum
Identify a backhoe
Doug Millett
11-13-2006 18:23:28
I have a '68 Massey 202 with backhoe that I have not been able to identify. Some have thought it was Pitman, others a Wayne Roy. Do you know where I could find pictures of early backhoes to ID the maker? This backhoe is swung from side-to-side by hydraulic pistons and not a motor. If you can be of help please contact Doug, [email protected]
135 Fan
11-14-2006 09:40:44
 Re: Identify a backhoe in reply to Doug Millett, 11-13-2006 18:23:28
Are you sure it isn't an MF hoe? Most backhoes use two hydraulic hydraulic cylinders for swing. Some have a rack and pinion swing and others use a rotary cylinder similar to a motor. Dave
135 Fan
11-14-2006 09:45:28
 Re: Identify a backhoe in reply to 135 Fan, 11-14-2006 09:40:44
Also, are you sure your tractor is a 68? I think the 202's were earlier than that. Dave
glennster
11-14-2006 06:24:20
i have a minnie moline big mo 500 combination. the loader is a minnie, but the backhoe is made by ottawa machine in nebraska. the unit swings by two cylinders with roller chains. the operator platform moves with the hoe. the out riggers telescope into the frame, they dont swing out like the newer style hoes.
BarryfromIA
11-14-2006 16:17:59
 Re: Identify a backhoe in reply to glennster, 11-14-2006 06:24:20
glennster how are you liking the Big Mo? I know for fact they are very good for pushing dirt with the loader.
jdemaris
11-13-2006 19:26:38
Does the entire hoe swing left or right - including the guy in the operators's seat? There's a MF 202 nearby for sale like that I was looking at awhile ago. Called a Workbull I think.
mn.Chuck
11-13-2006 19:26:03
Doug, It is likely to be a Massey Ferguson 185
backhoe. Originally built and sold as a Davis
185 backhoe. They had cylinders to swing the hoe
until the 210 backhoe replaced it. Chuck
