Tractor Talk Discussion Forum
Fuel not getting to cylinder
Jim Moden
11-12-2006 05:52:29
I have a 1939 F 20 tractor. It was running but I needed a manifold gasket which I replaced. I also at this time rebuilt the carb. Now it won't draw fuel up to the clyniders. The carb seems to have plenty of suction. The spark is plenty that it should fire. I did not do anything with the magneto. The plugs are Champion W18.
Jim Moden
11-14-2006 14:41:00
 Re: Fuel not getting to cylinder in reply to Jim Moden, 11-12-2006 05:52:29
Thanks guys, I figured out with much help. The magneto cap fireing order is 1-3-4-2. Somebody must have worked on the magneto because I had to advance the order by (1). Runs great now.
bradk
11-12-2006 06:02:12
It sounds like the float may be too low or debris is blocking the needle & seat after the rebuild.~brad
Nebraska Cowman
11-12-2006 05:57:19
Is fuel getting to the carburetor? Is fuel getting through the carburetor? Maybe as simple as being out of gas?
