Tractor Talk Discussion Forum
Water in oil
37 chief
11-11-2006 10:41:21
Water in the oil on my JD was caused by a hole in one of the poston liners. I removed all the liners and they all had a lot of small holes in the water side. What caused this problem? I recently purchased this tractor, so I don't know previous maintence history. Stan
Vern-MI
11-11-2006 11:37:08
 Re: Water in oil in reply to 37 chief, 11-11-2006 10:41:21
You have cavitation corrosion and it can be fixed by maintaining coolant at the correct pH level to prevent cavitation corrosion (rust) � the natural way in which metal converts back to its original ore form. Liner cavitation-erosion occurs along the thrust angle of the piston, especially in engines with wet liners. The liner sits inside the block and rings like a bell when the piston compresses and fires, causing intense pressure changes at the cylinder wall that result in liner cavitation. Liner cavitation, or pitting, is avoided by using an engine coolant with a nitrate component as it forms a monomolecular ultrathin oxide coating around the liner.
The pH should be maintained at levels between 7 and 8.5 in engines with soft and harder metals. A pH of below seven is more acidic and aggressive to harder metals, like cast iron or steel, while a pH above 8.5 becomes more alkaline to soft metals such as aluminium, copper and brass. It is therefore important to incorporate a coolant with a pH buffer, such as borate, to regulate the pH in coolant at safe levels. Approved coolant manufacturers offer fully formulated coolants that afford wet liner protection without the need to add extra additives.
Coolant dilution is an absolute must. If coolant concentrations was changed to 70% coolant and 30% water, the heat-transfer value would go up while corrosion protection will drop drastically.
bill mar
11-11-2006 11:03:26
from an earlier post
Coolant tends to become acidic over time. That. combined with cavatation in the block, and to some extent, dirt and rust particles in he cooling system, they're proned to electrolysis (also known as wet-sleeve pitting) The cylinder sleeves can end up with small pin holes that let all the coolant drain into the crankcase.
J Schwiebert
11-11-2006 10:48:48
In simple terms: The cooling system was not checked for the proper PH level of the antifreeze. It can happen to any of of them and can also be found on cast enblock engines. More questions?
