Tractor Talk Discussion Forum
puzzled about my to 30 charging system
sunny 4 acres
11-10-2006 14:07:54
Hey guys. My ferguson to 30 does not hold a charge. I put a battery load tester on my generator and it reads 7 volts. The battery reads 12 volts. The coil says on the side 6 volts. Cant find any voltage number on the square regulator. Can the supposed 6 volt generator charge the 12 volt battery? If it can oplease help me. Should I put on a 12 volt alternator? Im pretty non confident in the electrical dept
old
11-10-2006 14:52:30
 Re: puzzled about my to 30 charging system in reply to sunny 4 acres, 11-10-2006 14:07:54
If the genny hasn't been reworked it will not be able to keep a 12 volt battery charged up. Some how 7 volts just isn't enough to charge up 12 volt batterys. So you either have to have the genny worked on to put out the 12-14 volts needed or put a 6 volt battery back in or switch it over to an alternator
dan hill
11-11-2006 12:04:39
 Re: puzzled about my to 30 charging system in reply to old, 11-10-2006 14:52:30
A 6 volt generator will run wild and explode a 12 volt battery.Got a 55 chev that blew up a new battery.It pinned an ammeter, 30 amp. checked the generator, it was a 6 volt.
old
11-11-2006 16:44:28
 Re: puzzled about my to 30 charging system in reply to dan hill, 11-11-2006 12:04:39
Thats only because you either had a bad VR or you fried the VR. But if the genny system is working as it should it will not blow up a battery. By the way it also would have blown up a 6 volt
