Tractor Talk Discussion Forum
Farm-All Super A
David Drown
11-10-2006 10:04:58
When I start the tractor it stays at high idle regardless how I move the throttle lever. Any ideas why this is happening? Thanks in advance.
Dave
Cue P.
11-10-2006 14:33:56
 Re: Farm-All Super A in reply to David Drown, 11-10-2006 10:04:58
I had that problem too and thought it might be the gov. Before doing anything with that though i actually ended up redoing the carb. Dont know if the two were related but it seemed to take care of the problem.
old
11-10-2006 10:48:28
Govanor problem, broken gvanor spring, linkage binding some place any or all can cause that problem
IA Roy
11-10-2006 18:12:36
 Re: Farm-All Super A in reply to old, 11-10-2006 10:48:28
I worked for a neighbor in 72 and he had a 300 farmall that would run at the speed that it was shut off at. We had to shut it off at mid rpm so that is would work before it warmed up. I assume that there was moisture in the system and the governor was stuck at that speed.
