Tractor Talk Discussion Forum
3208 cat
jdnateinia
11-09-2006 13:13:44
I need to pull the injection pump on a 3208 Cat engine in a 4-150 White. Is there bolt under the pump or do I need to pull the entire front cover off.
oldcraneguy
11-09-2006 18:24:37
 Re: 3208 cat in reply to jdnateinia, 11-09-2006 13:13:44
And if its like a 3408 you need the timimg tool (also cat) to get it back in right
do the right thing
11-09-2006 14:45:15
Call your local CAT service department have them send a field mechanic... It may cost money but it will be less than you messing it up..
gfs
11-09-2006 18:15:36
 Re: 3208 cat in reply to do the right thing, 11-09-2006 14:45:15
Give me a break, the pump is easy, no matter what you use. There is a bolt it takes either a crows foot or an angled wrench 9/16 if memory serves. Take your time and make sure the pump is in time, find a manual and follow directions. No rockets or munitions involved.
KBS
11-09-2006 14:39:13
There is a bolt under the governor housing on this pump. You will probaby have to remove the intake to get to this bolt. You also may need a tool from cat to push the pump out of the drive gear. This is accessed by removing the tach drive on the front of the engine
