Tractor Talk Discussion Forum
Tractor Abuse!
Allan In NE
11-09-2006 05:13:40
Mornin' All,
Hate to keep harpin' on the subject, but I was visitin' with the boys over on the IH board yesterday 'bout this and many of 'em, I would suspect, think I'm running around with a coocked hat.
Dunno, maybe it is because I've spent my whole life trying to keep mechanical things running like they were designed to run and in good operating condition, but if ya take care of things, these old tractors will darned near run forever.
Anyway, from the first day I drove this latest 966, I could hear a noise in the rear end, so I finally had it opened up this fall and checked out.
Clearly, it has been overloaded. Overloaded to the point that the ring gear shows stress cracks and all the "pull" bearings are "pitted" from being subjected to way, way too much load. Somewhere along the line, this tractor has just plain had the guts pulled out of it, for whatever the reason.
It is a local tractor and the drawbar shows some egging, so I suspect it was used for farm work which was way, way too heavy for it's original intended use.
Yeah, I'm just venting because I'm the silly old sap that has to pick up the repair bill to make this tractor right agian.
But, can't people tell when they're "over doing" it? Can't they tell when the tractor is in over it's head? It is just like beatin' an animal that can't pull the cart.
Think this is one of my greatest "pet peaves" when it comes to old, used tractors. And yes, I know I'm too darned "picky", but abuse is abuse, no matter what ya call it. :>(
Allan
jiskies2
11-12-2006 20:44:49
 Re: Tractor Abuse! in reply to Allan In NE, 11-09-2006 05:13:40
i always thought it was a fine line between abuse and maxed out... and my dad couldnt fix anything while he farmed ,should say milked, for just under 50 years cause we still hay it. change oil, filters, etc; but I can't say I haven't pushed one tractor or another one time or another over the years! Heck that's we have 5 so there's always a spare if need be. none are pretty or new but all are paid for.
jeff
LBSMJS
11-09-2006 21:44:16
I can,t say for sure,but I would think the brg wear is from cheap hyd oil & not changing it like they should.The cracks are probably from dumping the clutch or some type of shock load.I also farm with a 966 that we put around 325-450 hrs a year on.It does the tillage,planting,raking,sq baling(6000-9000),grain cart(500 bu.),round baling(700),moves & loads round bales,& scoops the snow.It had 5500 hrs. before I rebuilt the engine.I have put on 1300 hrs since.I just fiquire it,s not pretty but its paid for.
buickanddeere
11-09-2006 18:45:27
There are those who use thier equipment and take care of it. A few hours and dollars or preventive service beats a preventable failure, an expensive repair and interupted planting or harvest. And there are those who in a matter of days, weeks or months. Have at least one cab glass broken,a cab door bent and won't properly close, exhaust stack bent, bashed in rad grills, lights knocked off. And they are eventually driving it around with most of the sheet metal removed. Oil and filter changes occur only when red lights flash or the radio can't be turned up louder to mask the nasty noises.
boo
11-09-2006 18:20:39
Why can't we all just get along....MY GOODNESS !!Ya'll gangin' up on Allen....
Aaron Ford
11-09-2006 18:01:27
When I got to tearing into my project tractor, I began cussing the former owner.
It was a plain mess. It was run til the pump broke, the front end trashed, the engine destroyed, the drawbar pulled off it, and the brakes were AWOL.
Then I realized, he was a farmer. He used his tool until there was absolutely nothing left. Can I fault him? Absolutely not. He did not have my comfy job, my heated garage, my tools, or my endless clock. He was a farmer. He used it til it was junk, then bought another. He was quite the unconventional engineer, but he apparently was successful at keeping it running.
There are alot of folk that simply cannot afford the tool they need to do the job properly. What can you do but make what you have work. When I was young, our 135 rarely had its front end on the ground, much less pointed in the intended direction of travel. The baler it towed was twice its size. The hillsides were murder. Yet there were mouths to feed and the local economy of the early 80's left little to go around.
I ain't sayin' that your tractor was not abused, but perhaps it's owner was like us, one mistake away from starvation, and one payment behind.
Sorry, just kinda hit home....
Aaron
730virgil
11-09-2006 15:17:53
friend's former s-i-l and his dad had 4840 john deere turning over 300 horses couldn't figure out why they couldn't keep engine cool and why they couldn't keep head gaskets on it . they also borrowed his 20 foot disk once . when they brought it back they griped that it wasn't any good couldn't make it work . they had changed all the setting and messed things up royal . he later found out they were trying to disk at 11 plus miles per hour . owners manuel said do not exceed 7 miles per hour
HAPPY DEERE
11-09-2006 14:57:03
my john deere's never get abused because all i get done i pulling my neibors tractor out of a field or a ditch iterally not ratting on internationals but its all i get done if you paint it red it lible to break paint it green and all your problems would be fixed forever
135 fan
11-12-2006 22:45:39
 Re: Tractor Abuse! in reply to HAPPY DEERE, 11-09-2006 14:57:03
I just saw this post. Your problems will be over alright. After you buy the tractor, you can't afford to even fill it with fuel so it doesn't get abused. The guy working his red tractor has to give you some coin for fuel so he can at least see if your green iron runs. When you do finally get it paid for, you have to park it again because it will need parts and you'll be broke again. No one make of tractor is better than another. I had an 87 JD crawler. Paid about $35 for a fairly thick operators manual that basically told me the bare minimum. I now have a cat and the manual is way more informative. I've seen other JD manuals that aren't much better. I guess they figure with all your money, you can just have the dealer fix it. The JD's from a few years ago were good tractors but were also known to be a lot harder on fuel than most others. You opened a whole can of worms and I have nothing against JD's except I know a couple of farmers up here that think they are the be all end all of tractors. Why do you think JD went into the turf business? More people are finding other tractors that are as good or better for a lot less money. In world wide sales JD is far from the top. Allans tractors look to be in tip top shape. Dave
BillyinStoughton
11-09-2006 14:11:12
Allan...you would sure as h*ll think someone would know when they were overdoin' it. I've never sat in the seat of any piece of equipment (even in my more naive years) and not known I was moving above and beyond the capabilities of what I was operating.
If you pay attention to what's going on (both sight and sound) will more often than not tell you the story about how hard you are workin' a piece of equipment.
I think implements get bought sometimes for the reason that they are "the right price"...and then once those implements get home, the new owner realizes that they are maybe a couple of horses short of a full team for the said implement. So what do ya do? Ya throw on more weight and more fuel! It fixes everything don't ya know!
Too funny how common sense makes no sense at all to some!
Glad ya got the 9 going and in good shape!
Billy
Jak
11-09-2006 11:31:32
I take it you wouldn't want to stick in a 466 in the 966 to help her out?He he,I know what your saying.I get ragged all the time because my F250 is very seldom muddy and I don't go mudding in it either.I know of a fella who turned a Case up and installed a bigger turbo and had a hoss for a while till the lift arms and hydraulics started getting slow.The hydraulic filters started filling up with shavings.After a filter change it would go a little bit and stopped up again.He put on one last set of filters and took it to a big sale.Whoever bought it was happy for a short while.
4010guy
11-09-2006 11:19:29
Well Well Well,,This has turned into quite an interesting discushun. My good neabor told me when i was young that if you treat a new impelment like an old one it will last forever.
Glen in TX
11-09-2006 10:59:49
Yeah some people can abuse any of them and just not take care of things. I never farmed with red ones but seen them get the job done too and cousin used them for years and worked on his own and others. From what I saw the 9 and 10 didn't have the planetarys or range trans and wouldn't take that kind of pulling and shouldn't be overloaded. Seen several he worked on that were treated rough and you would think someone driving one could hear gears insided shaving metal but maybe just don't care? lol. After seeing some go cheap and thinking I wanted one and learning about stuff like you are finding in yours I decided there were others to buy instead after seeing some that were probably in worse shape than yours.
RusselAZ
11-09-2006 10:20:12
My dad had several people in his life he didn't like because they abused horses in the same way. However, the gear train strain may not be as much about abuse as from being designed at minimum limits to achieve expected performance.
Howard H.
11-09-2006 09:29:19
I went to one of the most unusual farm sales anyone would ever see a couple of years ago out here in the Oklahoma Panhandle.
The fellow was a fanatic for maintenance detail like you would never believe. Every piece of equipment was perfect - some from the 30's and 40's.
The tires on the old Krause one-ways weren't even low.
The factory radio and cab upholstery in the old 930 Case was still perfect.
The old Massey cabless combine was still in perfect running condition.
The fellow was an aging loner, got sick, and hung himself from the windmill. But he wrote a notebook full of notes on most pieces of equipment for the auctioneers to post for the sale.
Things like "truck in perfect condition except slight oil leak on rear left axle - find seal on stairway in basement". Or on the old Model T - "note matching serial #'s - only thing that needs attention is hood mount blocks need to be shaved 1/16 of an inch".
He also left notes asking that no one who was not "authorized, competent, responsible, etc..." touch any of the cars in the barn.
The auctioneer stopped the sale at the 1940's grain truck and told the story that the owner told every farmhand they had hired during harvest, that if they were caught with the windows rolled down on the truck while it was still in the field or dirt road before they got up on the pavement they would be fired.
There was a 40's model Chevy pickup in perfect working condition - with a pintle hitch on the rear bumper that had almost 1/4" groove worn in the bottom hook. He had USED his equipment and taken AMAZING care of everything.
It was more like a museum selling out than an old farm estate.
The whole sale was eerie and sad and a good lesson at the same time. Reading his notes as different pieces were sold was very eerie.
It was sad that he died the way he did - alone and sick - but it has stuck with me as a lesson to this day that it is possible to take care of the equipment almost indefinitely. The amount of respect he had for taking care of things was inpirational.
To this day, it still affects my attitude on maintaining my tractors and equipment.
He also left the university where I work a good portion of a million dollar bequeath - so it paid off for his family to farm like that.
Howard H.
Hugh MacKay
11-09-2006 07:48:42
Allan: About the only way I know to keep tractors looking like new and as if they were never used, is just do exactly nothing more than look at them. 90% of 30+ year old tractors will have egg shaped drawbar pin holes and noisy rear ends. Are you telling us 90% of farmers abused their tractors. Some folks just used them a hell of a lot more than others. I can take you to dozens of farmers that achived massive net worths from farming in their life times, they didn't do it looking at tractors.
My dad had a saying, "The only man who never gets in trouble is the man who does nothing."
Allan In NE
11-09-2006 08:14:07
 Re: Tractor Abuse! in reply to Hugh MacKay, 11-09-2006 07:48:42
Hugh,
I disagree with ya. (What's new?) :>)
Using them correctly does not hurt a tractor one little bit. In fact, it is good medicene for the old beaters. It is what they were designed for. It is what they do and most of these old ones were way "overbuilt" to start with. They do not "wear out". They just don't.
Egg shaped drawbars are not a topic. Drawbars get beat up. Old tractors have egg shaped drawbars, fact of life and sure not an arguement there. But, you show me a bearing race that is flaking off and I'll show you an abusive operation somewhere along the darned line.
I will agree however that inactivity is probably the "worst" thing a guy can do with a tractor. Lettin' the tractor just sit kills 'em.
Now, I can certainly understand one dying from old age. That's normal and is to be expected.
It's just that I've just never been around a 175-year-old IH tractor and can't speak to that issue. :>)
Allan
Dr.EVIL
11-09-2006 08:59:14
 Re: Tractor Abuse! in reply to Allan In NE, 11-09-2006 08:14:07
This problem has been around since the days of steam engines.....But in the 30's & 40's it got worse. It got BAD in the 50's, the HP race years. High compression heads, biggers sleeves & pistons, stroker cranks....Make an M into a 70-80 HP tractor instead of a 36 hp....then Hook a 4-bottom plow & 12+ft disc behind it....instead of the 3-bottom & 9 ft disc. Then add a couple thousands pounds of weight because a 5000-6000# tractor can't pull 4 bottoms. And complain because the transmission & rearend can't handle it! ANY tractor that constantly pulls in LOW gears is over-loading the final drives, I don't care what color, model, etc. I saw a chart from AGMA, American Gear Manfacturer's Assoc. that shows as load or power thru a gear train is doubled the life expectancy is reduced to ONE Tenth. So with today's equip. I would say if Your tractor can't pull Your normal loads at least 4-5 mph it's over-loaded, the amount of ballast goes WAY up, slippage gets REAL bad...fuel efficiency dies....Speed doesn't spall bearings, stress crack gears, twist shafts.
Hugh MacKay
11-09-2006 20:31:47
 Re: Tractor Abuse! in reply to Dr.EVIL, 11-09-2006 08:59:14
Dr: I wonder if Allan read the section in his 1066 operator's manual, advising him not to use the 3 lowest gears for maximum drawbar pull with duals on. I expect similar applies to the 966.
Allan In NE
11-09-2006 09:20:28
Yeah I know,
But, Hugh and I just like to poke sticks at one another. It's what we do around here. :>)
Allan
Hugh MacKay
11-09-2006 08:34:53
Allan: There are 06, 56, 66 and 86 series tractor around with over 30,000 hours on them. There are tractors around that have seen hours go on at the rate of 1,500 hours per year. I have a friend in the logging business, about 6 machines, lot of same components as tractors and all of these see 3,000+ hours per year. His dad lived on welfare, he has a net worth in excess of $6,000,000. I'll bet that net worth was created by a lot of noisy rear ends. Please stop being so damn silly.
Allan In NE
11-09-2006 09:16:11
 Re: Tractor Abuse! in reply to Hugh MacKay, 11-09-2006 08:34:53
Now Hugh, Clam down.
Well, let's see. @ 3,000 hours a year on a farm tractor, that would pencil out to right at 250 12-hour days per year. 'Course, that's not stopping for fuel.
Come to think of it, that's not stopping for anything. Don't drink two cups of coffee 'cause we ain't got time to stop. :>)
I'm tellin' ya, you must have one heck of a long growing season up there. :>)
But, you may be right, I sure don't know. The most I've ever farmed was under 800 acres irrigated and couln't squeeze 200 hours a year on a tractor if I tried.
Maybe that's why I've never had a bad T/A or a bad rear end? You're probably right; guess I'm just being silly.
Allan
Hugh MacKay
11-09-2006 20:06:55
 Re: Tractor Abuse! in reply to Allan In NE, 11-09-2006 09:16:11
Allen: On 3,000 per year I said forestry equipment. Rod has already told you how it's done. My friend started out with nothing, at 48 years of age he retired with a net worth of $6,000,000. He ran them 30,000 hours each in ten years then shipped off to the parts man.
I ran my 1066, 10,000 hours in 8 years, a good bit of that was done on custom work. I had two young lads working for me that would leave home on Sun. night and run non stop until Fri night. It was summer work only pulling a root windrower doing clean up after bulldozers on land clearing. soon as the crop was in, silo full of alfalfa, they'd hit the road until the next cutting of alfalfa, and soon as that was done they were gone again. They averaged about 120 hours per week on the meter, and filled the silos much the same.
These guys travelled with camper behind pickup, fuel and supplies on pickup, tractor and rake and they quite regularly got 100 miles from home. I have seen them 150 miles from home but not often.
RodInNS
11-09-2006 15:41:11
There are several forestry operations in these parts that will buy a machine new, largely on credit. They've got one option. Run it 24/7. These are 1/4 or 1/2 million dollar machines, and that's what they do to keep ahead of the boogeyman. It's not uncommon to see 4 and 5 year old equipment pushing 10-12000 hours, and some gear that's 10 years old will have anywhere between 15 and 40000 hours. It's just about unbelivable how many hours they put on this stuff. You would literally have to see it to believe it.
Rod
dhermesc
11-09-2006 11:27:01
966 = 30 years X 1000 hours = 30,000 hours, if you don't think those kinds of hours won't put some wear in a transmission you have some awfully high expectations.
The last four 86 series tractors we sold were in the 20K to 25K hour range when 15-20 years old. I can guarentee that all of them had a little extra noise coming out of the rear end. Dad had 11K hours on his 1466 when he traded it in '80 for a 1486, he thought it had a lot of hours. He didn't know the tractors he was buying that year would end up with double the hours. The only tractors we owned that didn't see at least 800 hours a year were the 4X4s.
With only 200 hours a year you should go at least 20 years between between TAs. You're barely even getting the good out of an oil change in a year.
Allan In NE
11-09-2006 12:32:36
 Re: Tractor Abuse! in reply to dhermesc, 11-09-2006 11:27:01
Tell me how in the world you put that many hours on a tractor. I just cannot wrap my mind around it.
I'm used to irrigated farming, which is some of the most intensely "tractor use" farming there is. Most I ever remember squeezing on a tractor was one hundred seventy some hours in one season.
Please explain how you do it. Do you let the things set there and idle all night long or what? Or, are you farming in the 15, 20 thousand acre range?
Allan
dhermesc
11-09-2006 13:23:10
 Re: Tractor Abuse! in reply to Allan In NE, 11-09-2006 12:32:36
Double crop several hundred acres of wheat with a couple thousand acres of rowcrop, then put up over a thousand acres of hay - some of it with three cuttings, then feedout a couple hundred head of cattle and several hundred head of feeder hogs. In your spare time do some custom ground work for neighbors to make the interest payments.
The cattle and hogs alone will account for 10-20 hours of PTO work on a grinder every week. In a year's time that's 500 - 700 hours. That's before you even feed a bale of hay or a load of silage or clean a feedlot.
When I was helping out last spring the "new" combine had almost 1000 separator hours on it, the "older" combine had over 3000 hours seperator hours.
fixerupper
11-09-2006 07:42:22
Yep! People turn up the pump on a tractor and then brag about how much it can pull and all they did was write a check out to buy the thing in the first place. They had nothing to do with designing or building that machine, but they sure can brag about it. The people I work with bought a used truck with a 3406 Cat that the previous owner bragged about being able to pull so well after it was turned up. We replaced it's cracked pistons and sleeves last spring. Well, I know five of them were cracked, the sixth one was beat to death by the valves that were hammered through it. Then we turned the pump down 2 1/2 turns. And then there was the---- well, you know.... Jim
Allan In NE
11-09-2006 07:52:12
 Re: Tractor Abuse! in reply to fixerupper, 11-09-2006 07:42:22
Hear Ya,
Some folks can actually "feel" the stress of the iron, others just take another drink and full-bore ahead.
But, it takes all kinds to make the world spin tho.
Guess I'm just grumpy 'cause I've never before owned a tractor that has had 'er guts ripped out from pure, uncut abuse; be it intended or not.
Just torques me off a little 'cause I now gotta cover their tracks. :>)
Allan
RodInNS
11-09-2006 07:40:15
Hmmmm. I know you wouldn't want any of my tractors. They're all blue to begin with.... but they're all abused too. The philosophy is quite simple around here. If she can't pull it, add more weight. If that don't work, add more drive wheels. If that still don't work, add more weight again.... I've got an 86 hp turned to 105, dualed up, and ballasted to about 13000#. That's for some jobs. If I don't need the wheels, or the wieght, then I throw some off (both). It's just a fact of life. I can't afford to go out and replace her today with the 130 hp tractor I need, so I make do. So far the old sow's been holding up alright to the power and the wieght. I've had problems, but they've been in other areas not really related to that. She's right at 7000 hours now, and most of them hard.
Then there's the little loader tractor at 45 hp and 8000 #.... That's a story unto itself. It's also an example of what happens when front FWD axles are torqued out..... It costs... so we try to do less of that hard work with it now. I know what you're saying about abuse, but I think (and perhaps many do), that if you're getting away with it today, then we'll worry about it tomorrow.... `Course, I'd tell you what the tractor done before I sold it to you. Mabey some wouldn't....
Rod
barnrat
11-09-2006 07:25:19
I love tractor abuse, keeps my shop and pockets full. Those turned up Farmalls are money in the bank in my opinion. So are the turned up White 2-105's come to think of it.
third party image
third party image
Allan In NE
11-09-2006 07:42:07
 Re: Tractor Abuse! in reply to barnrat, 11-09-2006 07:25:19
LOL!
That's what I used to say about GM. "Bless your heart for that 700R4 tranny".
That under-engineered thing fed me very well for many, many years. :>)
Allan
the tractor vet
11-09-2006 07:00:59
WOOOOO OOOO there , just a min . on the abuce thing that rear end is just about the same on all of the 06 seires thru the 86 seires . And i have seen a lowey litttel old 706 gasser eat a rear because of a defective bearing . I had to rebuild the rear end on a 766 gasser from a bad pinion bearing that was a low hour tractor and here again a gasser . And a few years later had the same tractor twist the input shaft off just before going into the T/A, now myself i have never seen that happen before even on the tractors that we sorta made better by our standards and turnen the wicks up and i am not saint when running a pice of equipment as i have TRASHED on lots of stuff , If it would have been a horse it would had whip marks across it's back . Now over the years i have seen more problems on the 1466 and 1486's as to rearend problems . But here i have always thought that this was caused by turning at the headlands with the empelment down and standing hard on the brake and this would work hard on the spiders and side gears and case .Oh i should have said with duals on . Today can't get enough coffee in me and the teylenol is not getting the job done.
Allan In NE
11-09-2006 07:19:47
 Re: Tractor Abuse! in reply to the tractor vet, 11-09-2006 07:00:59
Yeah but Vet,
You know as well as I do that there is a big difference between "defective bearing", defective "preload adjustment" and the plain, old-fashioned failure caused from a bearing being "overloaded". You can see it in the bearing.
What gets me is that I would have sworn that the tractor needed bull gears. Just had that "sound and feel" to it. But luckily, that department looks just fine.
Red shop is installing the bigger stuff that the 10s and the 14s use, so it should last me to the end of my days anyway. He also agrees that they should be set up on the tight side of "spec". :>)
Allan
dhermesc
11-09-2006 06:25:31
How many hours?
Allan In NE
11-09-2006 06:44:40
 Re: Tractor Abuse! in reply to dhermesc, 11-09-2006 06:25:31
Showed 4601 the day I bought it and I probably have put something like 100 hours on it this past summer doing field work since the restoration.
When I get it home, I should scribble the hours down somewhere. When all the dust settles, I will have had something like $18K invested in the ol' brute from start to finish.
However, no stone has been left unturned. She's now new from the pivot pin to the lift sockets and it really is one heck of a nice old tractor..... ....(now). :>(
Allan
third party image
j cook (iowa)
11-09-2006 06:21:30
That's one of the models that all the purists make wild extravagant claims as to what hp the engine will make!
None of those people who are so proud of the 170 hp their "100" hp tractor delivers ever mention exactly what that mega hp actually does to the rest of the tractor.
Now you know!
Feel like doing the Farmal Owner thing and turn up any more of your tractors?
Allan In NE
11-09-2006 06:31:25
 Re: Tractor Abuse! in reply to j cook (iowa), 11-09-2006 06:21:30
No Sir,
I never did buy into that line of thinking. Just doesn't impress me in the least.
It'll pull what it'll pull and that's good enough for me 'cause I know it will pull forever at that load.
That smoke screw is nothing but a slow speed grinding wheel as far as I'm concerned. :>)
Allan
Rauville
11-09-2006 06:06:29
Production...production...production! Everyone has been trained to work harder and faster to produce more in less time. More land, bigger tractors, bigger equipment, bigger loans...all adds up to...you guessed it: "Tractor Abuse".
Here's some interesting data on labor vs. production:
When farming was first getting started in this country it took 300 man hours to produce 100 bushel of wheat, from soil preparation to harvesting and transportation.
Back in the 1930's that figure dropped to about 20 man hours.
During the 1950's it was down to about 5 man hours.
Today, I would guess we are approaching 2 man hours for that same 100 bushel.
NO tools
11-09-2006 06:03:32
ABUSE IS ABUSE i don't care how you look at it some people just plum don't know any better.1066 9000 hrs 1 clutch 2 sets of tires in it life.never done more than 4 16plow 14ft disc.TA weak but i'll put her with a new one in her class.Allways ready to tackle something?yes we open it ck things once not to bad. Neighbors 1066 8500 hrs 4or5 sets of broken down tires 22ft disc 6 16 or 16 or 17 shank chisel plow.?ell yes it will pull loaded 20.8 38 6 sets weights cast iron dauls does a real job when it out of the shop 12 14 weeks a year.NO he don't ask any more ?ell no if i get time i'll come over.
dej(JED)
11-09-2006 05:35:46
Do you know why they painted JD's green and yellow? So they could hide in the corn fields , while the Farmalls did the work.
Pete in MD
11-09-2006 20:41:21
 Re: Tractor Abuse! in reply to dej(JED), 11-09-2006 05:35:46
Farmalls are painted red so you can find em where they broke down in the corn when you're heading back out from the shop to retrieve them.
Allan In NE
11-09-2006 05:41:54
Heck! I like 'em all.
Don't even get too worked up over those "blue colored" things. :>)
Allan
WyoDave
11-09-2006 05:32:51
I won't lie, I've probably overloaded and abused a tractor every once in awhile. I don't do it often or for extended periods of time, but sometimes you do what you have to do with the equipment you have. Of course I drive Deere's and everyone knows you can't overload them. ; )
David
Allan In NE
11-09-2006 05:39:29
 Re: Tractor Abuse! in reply to WyoDave, 11-09-2006 05:32:51
Well, there ya have it. Knew I was doing something wrong. :>)
Where would a guy pick up one of these John Deere tractors reasonable like?
Oh, that's right. Forgot. Ya can't buy a green anything without paying three times the money.
Guess I'll just pay the repair bill and keep my yap shut. :>)
Allan
WyoDave
11-09-2006 05:53:23
 Re: Tractor Abuse! in reply to Allan In NE, 11-09-2006 05:39:29
Yeah, repair bills are a pain, but now you'll know what you have, and be the only operator so you can drive it how you feel fit and know that it'll last as long as you need it to. Then when you get tired of it, I'll know what you've done to it and be standing in line for it. David
dej(JED)
11-09-2006 05:50:30
Allan-I have got 2 JD 5020's I can put you into at a really reasonable price. 133 HP. But should you still prefer Red I also have a 1486 at a reasonable price also.
B-maniac
11-09-2006 18:48:27
 Re: Tractor Abuse! in reply to dej(JED), 11-09-2006 05:50:30
He better take the 5020,it's built to handle it's power, the 1486 isn't.
Allan In NE
11-09-2006 06:06:34
Don't temp me!
I'm right in the middle of a tractor-swap-talk-nonsense right now for a 1486 vs any one of my pretty red ones.
However, if I bring home one more tractor, I know darned well I'll be spending my evenings out in the barn! (Some things ya just know without being told.) :>)
I've got six guitars and five tractors. Lookin' for the loonie-bin squad to show up at the door just any day now.
"Paging Allan, paging Allan, paging stupid old Allan". :>)
Allan
Allan In NE
11-09-2006 05:26:30
 Re: Tractor Abuse! in reply to dej(JED), 11-09-2006 05:21:57
Snicker! :>)
I told the wife that the only way we can realisticly deal with this current situation is to shut off the nightly newscast.
It's ust too hard on the old ticker. :>)
Allan
135 Fan
11-09-2006 11:36:16
 Re: Tractor Abuse! in reply to Allan In NE, 11-09-2006 05:26:30
It doesn't matter what colour they are, they all break down sooner or later. Maintenance helps make it the latter. Using really good lubricants and checking and changing them regularly makes a big difference. I've seen a lot of guys that never fix leaks, buy the cheapest oil they can find and just keep filling it in the morning. Who knows how much damage was done the last couple hours the day before cause the fluid was low. Then they always complain about how expensive it is to fix. You mention a little preventive maintenance to them and they get mad at you. They think it's a miracle that the neighbor gets so much trouble free life out his older higher hour machines. They figure he has more money. He has more money but only because he did a little regular maintenance. Some people do seriously abuse their equipment. It will catch up to them. Dave
