Tractor Talk Discussion Forum
PTO to Belt drive
Bill Okrasinski
11-06-2006 12:59:41
Hello, Does anyone know of an adaptor for a TO30 Ferguson that converts the rear PTO so you can run a belt. Primarily for running a BuzzSaw.
steveormary
11-06-2006 17:23:45
 Re: PTO to Belt drive in reply to Bill Okrasinski, 11-06-2006 12:59:41
Bill
If you have the belt pully for a Ford or Ferguson with the 11/8th pto shaft you shouldnt need an adapter. The pully should bolt right up after you take the sway chains off. Also,bolt the pully so you have to give the belt a twist to run the blade in the right direction. We bolted ours so the pully was on the right side looking toward the back of the tractor.
steveormary
steveormary
11-06-2006 17:23:25
Bill
steveormary
Dave Sherburne NY
11-06-2006 14:20:08
I've got one What size is your PTO?? The splines are measured at the largest dia. shoud be 1 3/8" or 1 1/8" . Where are you?
jhill52
11-06-2006 13:14:33
Both Ferguson and Ford made belt drive adaptors. I see them alot at auctions. Also try Ebay.
Jerry
Bill Okrasinski
11-06-2006 14:22:41
 Re: PTO to Belt drive in reply to jhill52, 11-06-2006 13:14:33
Thanks. After a lengthy search on the web, I only found two and both were on Ebay, and for Fords. Surely there must be more of them out there. Does anyone have specific information about them?
430WLPG
11-06-2006 18:48:42
 Re: PTO to Belt drive in reply to Bill Okrasinski, 11-06-2006 14:22:41
I have one for a Ferg
Leroy
11-06-2006 17:22:17
No difference for the Ford or Ferguson tractors, The only thing you need to watch for is shaft size but one sold by Ford fits Ferguson and vice versa.
jhill52
11-06-2006 15:51:51
What information do you want?
