Tractor Talk Discussion Forum
JD motor question
37 chief
11-06-2006 12:55:13
I am doing a rebuild on my JD 401 industrial. It has a 4 cyl diesel. I removed the pan and see two shifts on each side of the block below the cam level. the book calls these balancing shafts, What actually do they do? Stan
buickanddeere
11-07-2006 05:57:46
 Re: JD motor question in reply to 37 chief, 11-06-2006 12:55:13
Unlike a V8 that is pretty much inheritly balanced. The inline 4 does not cancel centrifical forces in either the X and Y axis. The balancer shaft swings it's offset weights to counteract the force of the reciprocating and rotating components.
CRUSADER
11-06-2006 16:57:33
Hey Chief,
This is a balancer. It's been MANY years since I worked on one (prior to joining the military in 85) but if memory serves me correctly...be sure to put the balancer back in correctly and timed. If not, that thing will try to jump sideways accross the shop. I didn't learn this lesson the hard way, but was present when someone else did. This was a lesson I will never forget. Good luck with the rebuild.
Jim
jdemaris
11-06-2006 15:58:51
It's usually only needed with four-cylinder engines. Threes, fives, sixs, etc. don't have the same harmonics problem. They balance the engine at certain RPMs. Deere left them out as a cost-cutting factor with some of those four-cylinder engines - e.g. the early 210 backhoes. They vibrated so bad the muffler would break from rattling around. Bigger four-cylinders - e.g. the 3020 use balancing gears instead. Years ago there were several cars around that used them. Remember the Silent-Shaft Plymouth Arrow?
jhill52
11-06-2006 13:16:16
They dampen the vibrations from the crankshaft.
