Tractor Talk Discussion Forum
Internationl 424 coil?
Eric Price
11-06-2006 06:46:43
I have an international 424, gas, 4cyl,. it runs about 50+ yds and dies.
I have changed points, condensor, coil, plugs, voltage regulator is fairly new.
All of this and still the same results.
Please help!!!!
Tim in New York
11-06-2006 16:11:56
 Re: Internationl 424 coil? in reply to Eric Price, 11-06-2006 06:46:43
Eric,
I had a similar problem with my 2424. Turned out to be a small chunk of something, maybe golden rod stem, that kept getting sucked into the outlet in the fuel tank. I think I figured it out by removing the sediment bowl and discovering that fuel would only drip from the stem on the bottom of the tank. Got it out somehow - can't remember now. It was years ago.
good luck!
Tim in New York
old
11-06-2006 07:11:19
As soon as it dies check for spark. If you don't have spark its probably a bad condenser or ignition switch. If you have spark then check gas flow by takeing out the carb drain plug. If you don't have a steady flow of gas then you problbly have a clogged fuel system or carb problems
Eric Price
11-06-2006 07:22:49
 Re: Internationl 424 coil? in reply to old, 11-06-2006 07:11:19
thanks i'll check that.
RustyFarmall
11-06-2006 06:59:49
Are you sure the problem is electrical? Could be fuel related. Try removing the fuel tank cap. If that doesn't do it, check out any filters that may be in the gas line.
Eric Price
11-13-2006 14:14:03
 Re: Internationl 424 coil? in reply to RustyFarmall, 11-06-2006 06:59:49
tried removing gas cap. did not work.
globe stays full at all times and is full when tractor quits.
no filters anywhere. (might need to add one).
Eric Price
11-06-2006 07:26:36
when it does die it will not start for a couple of hours.
I'll look into the fuel system.
maybe check the gas globe when it dies to make sure the fuel pump is working.
IH2444
11-06-2006 08:12:19
 Re: Internationl 424 coil? in reply to Eric Price, 11-06-2006 07:26:36
It could be downstream of the fuel pump....
Eric Price
11-06-2006 08:15:26
 Re: Internationl 424 coil? in reply to IH2444, 11-06-2006 08:12:19
TRUE ENOUGH.
THANKS,
