Tractor Talk Discussion Forum
manifold studs for a 51 a JD
skoal ring
11-05-2006 05:48:52
can anyone tell me where to get manifold studs for my 51 a jd i need all 4 and how to install them
Pappy
11-05-2006 23:42:01
 Re: manifold studs for a 51 a JD in reply to skoal ring, 11-05-2006 05:48:52
I am about ready to replace the manifold on my "52 "A" and I plan to use bolts. I have found that head bolts from an old Chevrolet engine will fit. Probably out of a 350 CI. I will have to recheck length for accuracy before installing, but they come pretty close.
Rusty Junk TX
11-04-2006 18:07:18
The first tractor I restored was a 51' "A" in 1998. I replaced the manifold and used studs with anti-seize. I had to replace the gasket about 2 or 3 years ago. I got lucky and got all four studs out. Every tractor since that tractor got bolts. If things did not go that well, off comes the hood,radiator and fan shaft assembly. USE BOLTS. To-the-heck with the "correct police".
Marcus
HAPPY DEERE
11-04-2006 13:40:32
i agree with 960 unless your doing an expo restoartion just uzse a good grade 8 bolt but if not i would try a man by the name of kent kaster of kk antique tractrs the number is (317)398-9883 he is where i order 50% of my parts from if i need a new part all toghether also you can try dennis polk of polk equiptment.
960
11-05-2006 06:03:56
Unless you are doing an expo restoration forget the stud idea and use hard bolts with never sieze. If you ever have to replace the gasket or manifold you will wish you used bolts.
