Tractor Talk Discussion Forum
slow cranking farmall
bradhowNE
11-02-2006 15:48:06
Hey guys, I hope there is a good answer as I am at my wits end. Farmall 200 (super c)turns over so slowly that I cant get it to fire...replaced battery,replaced ground cable,had the starter checked at two different shops and checks out good,replaced solinoid,fired once for about 30 seconds after i messed with it for several hours,so I know its getting spark and fuel,any Ideas would be greatly apprecieated Brad How NE
Dave_Id
11-02-2006 16:15:50
 Re: slow cranking farmall in reply to bradhowNE, 11-02-2006 15:48:06
I would have to agree with JiminIowa. If your cables are too small with a 6 volt system, you can't get the voltage thru. It would turn over quicker with a hand crank.
buickanddeere
11-02-2006 16:07:55
While cranking what is the voltage measured between the post on the starter motor it's self. And the cast iron body of the starter? Is the timing backed off the TDC while cranking?
JiminIA
11-02-2006 15:53:11
Make sure you have a good clean ground first. Also are you using heavy enough cables. I use 1/0 0r 2/0 on all my 6 volts and alot of my 12v as well makes a big differnce. Those are uasally the culprits if not it may be the starter or even the switch not making good contact.Hope this helps I am sure plenty of others will add as well.Stay Safe....Jim
