Tractor Talk Discussion Forum
Wiring diagram for International model 3444
Lee Browning
11-02-2006 15:36:04
Just bought an Internationa model 3444 diesel frontloader and the wiring is all messed up. Have installed new glow plugs and do not know how to connect them. Cannot connect 12v direct as that burns them out immediately. If anyone knows how to connect the glow plugs and/ or has a wiring diagram please contact me.
Thanks,
Lee Browning
[email protected]
Bob
11-02-2006 15:48:32
 Re: Wiring diagram for International model 3444 in reply to Lee Browning, 11-02-2006 15:36:04
Each glow plug, when you look closely, has 2 terminals, insulated from each other, and from the screw-in shell (ground).
The glow plugs are wired up in SERIES.
Power is applied to the BACK (#4) glow plug. It's other terminal gets jumpered ahead to one of the terminals on #3. #3's other terminal gets jumpered to #2, etc., with the last of the terminals on #1 being connected to the block, (GROUND).
Lee Browning
11-02-2006 19:25:33
 Re: Wiring diagram for International model 3444 in reply to Bob, 11-02-2006 15:48:32
Bob,
Thanks,
That is what I figured and have them wired that way, in series. I wanted to get confirmation before I connected the power.
Again, many thanks,
Lee
Bob
11-02-2006 23:42:07
 Re: Wiring diagram for International model 3444 in reply to Lee Browning, 11-02-2006 19:25:33
You also have the dash-mounted glow resistor thingy in the circuit, right?
Lee Browning
11-03-2006 18:22:15
 Re: Wiring diagram for International model 3444 in reply to Bob, 11-02-2006 23:42:07
No,
The wiring on the tractor was really messed up and none of the gauges worked. I installed new gauges, starter switch, alternator and a bunch of other stuff. Any bulbs that were there are gone. Do you have a wiring diagram?
Thanks,
Lee
