Tractor Talk Discussion Forum
(OT) Sorry to bother you guys with a truck questio
Truth seeker
10-27-2006 10:33:23
Hi!
It's been a while since I last posted on here,,,,
I have just got a '92 Dodge 250 truck equipped with a Cummins, and have been working on it, on and off, and now I almost almost have it done! (just need to get the 35 gallon -ouch- tank back on).
Anyway does anyone know where the fuse box is on this thing? I've looked, but I can't even find my own nose!
I noticed that Farmall_Ryan had found a Ford manual online.
Farmall__Ryan, Could I ask you, where I might find a manual for my truck? Thanks In advance!
P.S. My spllenig is porblye offf today ;)
Luke S
10-27-2006 14:30:26
 Re: (OT) Sorry to bother you guys with a truck que in reply to Truth seeker, 10-27-2006 10:33:23
It's right under the steering column. Easiest to get to by laying on the floorboard on your back. It's just on the backside of the plastic, held on by a little clip.
tmay
10-27-2006 14:07:06
I went to Auto Zone and bought a manual for my truck. It is the Haynes repair manual. It will lead you through step by step on how to do things and has all the areas that you were looking for shown. Hope this helps and good luck
ErnieDD
10-27-2006 18:06:30
 Re: (OT) Sorry to bother you guys with a truck que in reply to tmay, 10-27-2006 14:07:06
I got 3 Haynes Manueals, I keep in the bathroom close to the commode. Case(s) in point:
a) Changing fuel pumps in both Silverado and Venture vans, they instruct you to syphon gas out of fill tube. You can't there is a check valve that makes it impossible.
b) Changing primary O2 sensor on (ad)Venture, give no intruction on how to disconnect inaccessable wire connector.
c) Broke hood release on Silverado, told you how to change the cable but not how to release the hood to access the latch.
Haynes needs to have more real world experience in their book, I wrote a letter to Haynes a year ago, still waiting for my reply.
Davis In SC
10-27-2006 11:00:14
I have that same model truck.. IIRC, it is below thr steering column, I think I remember taking a few screws out, to remove a small cover. It has been years since I had to get to the fuse panel on mine, so my memory is a bit foggy.
Chad Franke
10-27-2006 11:51:43
 Re: (OT) Sorry to bother you guys with a truck que in reply to Davis In SC, 10-27-2006 11:00:14
I don't think they are screws, but quarter turn type fasteners, with a wing nut looking deal...but I think that's where it is, under the dash panel below the steering stem...
