Tractor Talk Discussion Forum
Allis B Magneto
Stan(PA)
10-26-2006 14:54:42
Background: I haven"t started this thing in a year, but it ran last year. It was ALWAYS very hard to start, but seemed to run pretty good once I got it fired.
Now: Tried to start, and it turned over REAL SLOW. (always did turn real slow). Barely one rev, and battery was gone. I put in my best 6 volt,fully charged battery, and she still turned REAL slow. Got about 6 revolutions, 3 different times, and she dragged the battery down. Recharged battery. Checked archives, and found that #1 should be on upper left Mag nipple. My #1 was on LOWER RIGHT nipple, and 1,2,4,3 from there. Switched wires to start at upper left nipple. Now she turns over quite a bit faster, but still no start.
BIG QUESTION: Could this thing have been running with the wires that far off??? I know about as much about Mags as I know about the reproductive cycle of the blue ringed octopus, but it looks like I"ll have to tear it down, and start from scratch. Sure would like to know how it was running before though!
Mag experts are invited to give any, and all input.... Stan
Glen in TX
10-26-2006 21:42:37
 Re: Allis B Magneto in reply to Stan(PA), 10-26-2006 14:54:42
Timing could still be off and yeah starter may need worked over too. If mag isn't turning over well may need to oil or flush out impulse till it's clicking good and turning over faster too. Link below to Rod's timing page.
old
10-26-2006 16:30:19
I'm not an expert but I know that the mag can be put on the correct way and also 180 so your is probably 180. If you drop me an e-mail I can send you a copy of a mag manual some one else sent me. Sounds sort of like your impulse isn't working as it should and that you now also have it 180 out the timeing. You also may have a problem with dry cylinders and a weak starter. I would put a little tranny fluid in the cylinders and also have the start checked to make sure is not weak
