Tractor Talk Discussion Forum
O.T. Steering wheel pull
science teacher
10-23-2006 14:36:08
Sorry for the topic but you guys always h ave hte answers. I have a 98 Honda accord. It was alligned agout 3 months ago because of tire wear. It doesn't wear anymore but has a very noticable pull to the right. At 1st I attributed it to the road crown but after driving on the left on the interstate I can now tell it is not that. Is there anything else other than allignment that can cause it to pull????
Thanks to all you experts out there.
Jimmy King
10-23-2006 16:33:08
 Re: O.T. Steering wheel pull in reply to science teacher, 10-23-2006 14:36:08
A slipped belt will cause it to pull, as the other post said swap sides with it and see if it pulls the other way.
hlc
10-23-2006 15:05:44
A tire can cause a vehicle pull to the side. Swap the two front wheels and if the car pulls the other direction it is the tire causing the problem. Been there and done that.
RustyFarmall
10-23-2006 14:50:13
Was a full, four wheel alignment done? The crown in the road shaould cause a pull to the left, unless you are in the left lane, and then the pull would be to the right, but in either case the pull should be barely noticeable, if at all. Mismatched tire sizes, under-inflated/over-inflated tires will cause this, or, as the other poster already noted, dragging brakes, but if just one brake was dragging that much, I think you would notice a lot of heat and or brake dust on that particular wheel.
glennster
10-23-2006 14:38:31
check for a front brake hanging up. the sliders on the calipers get stuck and drag causing a pull.
