Tractor Talk Discussion Forum
Loader removal
kestrel
10-23-2006 06:42:49
third party image
It wasn't pretty, easy, or safe but its done. What methods do you guys use removing loaders when alone and with no overhead lifts ?
There are no good hanging limbs here on my property so I used a bottle jack, two jack stands, and a ton of scrap lumber.
Meanwhile, this little Case now handles like a sports car. I never drove it without the loader and may just keep it off, until a distinct need arises. Besides, I don't even want to think about putting it back on any time soon. Thanks for any input.
Kestrel in CT
Kestrel
10-23-2006 17:21:08
 Re: Loader removal in reply to kestrel, 10-23-2006 06:42:49
Thanks guys. As usual, your responses provide good practical solutions.
My hydraulics run off a crankshaft extension that drives a front mounted pump on the loader so I can just leave the hoses alone. I like Dell's timber A-frame idea with a block & tackle. Also plan to recruit a neighbor this time when remounting and work on my patience.....I am supposed to be retired after all.
Kestrel in CT
Dan-IA
10-23-2006 10:17:25
Well, the easy answer is that the westendorf loaders, you flip the locks on the front of the tractor, put the bucket on the ground and back away slowly while using the hydraulics to "raise" the loader. Then it sits on the bar with the locks, and you go unhook the hoses.
As for our loaders... With the stanhoist loader on the 560, we pull the two pins on the bottom of the hydraulic cylinders,set them on the ground, pull the pins at the hinge point, unhook the hydraulics, and back away. That leaves the mounts on either side. For those, we use a chain hoist on U-bolts in the shop rafters and a couple log chains to support it while we unbolt the mounts.
If we didn't have that, we'd probably use another tractor/loader or skid loader to support it.
Again, sans another loader, we'd cut up a couple big blocks of wood like we use to support cars when we work on them, and probably break out the old antique hi-lift jacks to do any lifting required on the loader mounts. Bottle jacks would probably also be enlisted in a pinch.
Ken Crisman
10-23-2006 07:29:47
I know just how it is with being alone & trying to do things . I had built a heavy duty wood swing frame in my yard for my X . Well since its all mine now I removed the swings & used that to man handle my loader . I had bought a cheap-o set of chainfalls for such projects . Then there was another dilema , I didn't want to leave the loader in the middle of my yard . So I welded a trailer together just for the loader to sit on . The setup worked so well I hauled it down to my garage , sandblasted it , & painted it Ford Red . Now I have a nice black steel trailer & red loader sitting portable in my yard . I can move it around as I need to . Play safe & God bless . Ken
Janicholson
10-23-2006 07:27:23
As stated below, be careful. I have used a pipe based system that looks like a swing set. Schedule 40 2" pipe and some 90 degree elbows and a bit of welding to attach the second leg to each elbow, will make a $120 insurance policy. JimN
glennster
10-23-2006 07:23:30
i made 2 braces that bolt to the rear of my loader on my m. i used 3X5 by 1/4 wall rectangular tubing with a piece of 3x5 welded to the bottom of each for feet. the feet sit about an inch off the ground when bolted up to the loader. . pull in the shed, bolt the brackets on, loosen the loader, raise the bucket just a little, back up a hair and lower the loader so the feet sit on the ground. then unhook the hydraulic hoses and back away. it looks like an upside down "T". takes about 1/2 hour to mount or dismount.
Farmer in the Dells (WI)
10-23-2006 07:09:56
Without a doubt the two things that bother me here is you stating it is not safe and you are alone. Since it will be awhile before you remount it, I would build the right frame to make putting it on or off easier. Even a timber "A" frame with block and tackle or boat winch rated for the weight might be the ticket. Something with a safety stop built in. Don't forget to add a couple of well placed eyehooks under the cross member. When not using it hang a two seated swing on it to use when the day is over.
Not sure how it mounts to the tractor but is there a way to put the bucket down and brace the rear connections in a "three point stance" using the hydraulics before disconnecting and then backing off it? Allan might have better insight since he is always up to something in this area. Allan?
