Tractor Talk Discussion Forum
JD 202 Gas rebuild or replace?
Larz
10-22-2006 19:49:42
My JD 3300 combine with the 4-202 Gas engine went bad. Removed and examined crank ... burnt bearing on a piston rod. It has 2500hrs but has a new top end. Should I consider rebuilding or look at replacing with a diesel (4-219 or 4-239)? Any advice or ideas are appreciated. I like the combine and hate to scrap it!
Larz
Mike M
10-23-2006 05:35:49
 Re: JD 202 Gas rebuild or replace? in reply to Larz, 10-22-2006 19:49:42
If you know the top end is good and since you have the crank out I'd just get it ground and put it back in with new bearings and don't mess with the top end.
Leland
10-22-2006 19:54:33
What ever costs the least here it won't take long to put more money in this beast than it's worth
