Tractor Talk Discussion Forum
wiring 53 jubilee
doug kamauff
10-22-2006 16:30:41
can some 1 tell me where all the wires go on a 53 jubilee thank u very much draw a pitcher or anything would b great
Bob
10-22-2006 17:18:21
 Re: wiring 53 jubilee in reply to doug kamauff, 10-22-2006 16:30:41
Here's a diagram, but it is NOT 100% complete, in that only the primary wire TO the coil, FROM the ignition switch is shown. The primary wire from the coil TO the distributor is NOT shown, nor is the distributor, but you understand from my previous post what wire from the coil goes to the distributor, RIGHT?
Third Party Image
doug kamauff
10-22-2006 20:46:31
 Re: wiring 53 jubilee in reply to Bob, 10-22-2006 17:18:21
thank u that helps me out a lot ok so does the wire from switch/terminal go to+ or - side of coil
Bob
10-22-2006 22:22:15
 Re: wiring 53 jubilee in reply to doug kamauff, 10-22-2006 20:46:31
If your's is still as-original (+) ground, the power wire FROM the ignition switch goes to the (-) side of the coil.
For a (-) ground system, the power wire from the ignition switch would go to the (+) side of the coil.
Bob
10-22-2006 17:18:15
Third Party Image
