Tractor Talk Discussion Forum
glow plugs
bm3501466
10-20-2006 15:52:46
How do you test to see if a glow plug is working or not working? I have a chevy with a 6.5 in it and it starts rough. It seems like some of the glow plugs aren't working. How do you determine which ones are bad?
Larry806
10-20-2006 18:39:40
 Re: glow plugs in reply to bm3501466, 10-20-2006 15:52:46
Quickest & easiest take a test light and clip on to the positive side of the battery. Pull the wires off the top of the glow plug. touch the probe end of the test light to the clip on top of the glow plug. If the light ,lights up it is good. If it doesn't light that glow plug is bad.
Mike (WA)
10-21-2006 08:22:32
 Re: glow plugs in reply to Larry806, 10-20-2006 18:39:40
On the Ford 6.9 and 7.3, glow plug should have about 2 to 3 ohms resistance. Chev probably about the same, I would think.
Joe(TX)
10-20-2006 16:50:43
Check the continuity of the glow plug. If it is open it is not working. A common problem for the Chevy's.
jdemaris
10-20-2006 17:39:23
 Re: glow plugs in reply to Joe(TX), 10-20-2006 16:50:43
It's not a problem if he uses a better plug. The orignal ACs were garbage and will burn out pretty easy. If you buy new plugs now - in the AC box - they are actually made in Germany by Beru - just like the Ford 6.9s and 7.3s use. These have built-in circuit limiters and hold up fine.
