Tractor Talk Discussion Forum
TO30 1950 Massey
Stewitup
10-19-2006 11:17:51
I bought new parts for PTO replacement and I can not get the old shaft out is there a trick to it?
I removed the engaging fork and removed rear cover bolts but it wont budge!!!!
Jerry/MT
10-19-2006 19:33:28
 Re: TO30 1950 Massey in reply to Stewitup, 10-19-2006 11:17:51
I hate to tell you this but you shaft might be twisted and won't come out of the hydraulic pump. You usually have to cut the shaft and ytake it out in pieces. Go to the Harry Ferguson Forum and do an archive search. This topic has been discussed there before.
mn.Chuck
10-19-2006 18:59:29
Sounds to me like someone used a "hardening"
gasket cement. If so you may have to heat. It
should loosen though if you carefully tap the
Hsg trying to rotate the cast Hsg. back and
forth. Good luck
