Tractor Talk Discussion Forum
Belarus 250 AS
Jason21
10-14-2006 22:25:53
Does anybody know if a belarus 250 AS will pick up a roll of hay ???
Jim Johnson
10-15-2006 05:59:59
 Re: Belarus 250 AS in reply to Jason21, 10-14-2006 22:25:53
My father-in-law has a 37 HP kubota and it will, with ease, just need some weight up front. Don't know if this helps any as I know nothing about a Belarus.
jmixigo
10-15-2006 15:24:15
 Re: Belarus 250 AS in reply to Jim Johnson, 10-15-2006 05:59:59
If yore comparin a Bellroos to a Koobota-Then no you don't know nuthin bout no bellaroos.
Nebraska Cowman
10-15-2006 05:23:35
With lift capacity at 1350 I doubt it. That measurement is done at the end of the arm and with the bale behind that point the required force would be much greater. It might lift a 500 pound bale.
Belarus
250AS
Manufactured: 1979 - 1987 Factory: Minsk, Belarus Cost: (US Dollars) 8000 (1987) Power: Engine (HP): 31 Drawbar (HP): 22 PTO (HP): 24 Engine: Manufacturer: Belarus Fuel: diesel Cylinders: 2 Bore/Stroke (inches): 4.13x4.72 Displacement (ci): 127 Compression: 16:1 Rated RPMs: Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Type: sliding gear Forward: 8 Reverse: 6 Capacity: Fuel (Gal): 14 3-Point: Category: II Lift (lbs): 1350 Power Take-off (PTO): Type: live Rear speed (RPM): 540 Hydraulics: Type: open Capacity (gal): 2 Total Flow (gpm): Outlet Flow (gpm): 4.2 Pressure (PSI): Outlets: 1 Tires: Ag front: 6.00-16 Ag rear: 10-28 Dimensions: Weight (pounds): 4,300 Wheelbase (inches): 69 Length (inches): Width (inches): Height (inches): Ground clearance (inches): Electrical: Battery volts: Ground: Battery cold-cranking amps: Alternator amps:
Trkr
10-15-2006 07:06:23
 Re: Belarus 250 AS in reply to Nebraska Cowman, 10-15-2006 05:23:35
Not sure about the hydraulics stats listed here,but it says live pto.A 250 Belarus does definitely not have a live pto,and was not an option on one.
jokers
10-15-2006 12:39:58
 Re: Belarus 250 AS in reply to Trkr, 10-15-2006 07:06:23
You`re right Trkr, the 250 does not have a live pto.
I had a nearly new 250 for about a year, several years ago. It was honestly the worst piece of equipment that I`ve ever had and replacement parts cost a fortune. I got sucked into it because it seemed like alot of tractor for the money, boy was I mistaken!
