Tractor Talk Discussion Forum
Ferguson TO20 lift quadrent
Nebraska Cowman
10-14-2006 05:56:25
When I lower the implement the lever does not stay down. Do I just need to increse the friction or is it an internal problem? Our club is featuring Massy & Ferguson for 2007 and I gotta get this tractor ready to plow!
Jerry/MT
10-14-2006 15:26:57
 Re: Ferguson TO20 lift quadrent in reply to Nebraska Cowman, 10-14-2006 05:56:25
I had the same problem because my cork friction disk was plumb wore out. I replaced it and adjusted the tension via the nut that holds the lever on and it stays where I put it now. If your friction disk is OK, then you can just tighten the nut down but if it's not, you'll have to make one (use some 3/16" cork gasket material) or buy one. Walt's Tractors sells 'em for a buck a piece last time I looked.
PS Glad to hear you doin' fine and back at this old tractor business.
