Tractor Talk Discussion Forum
offset disc broken frame
haweater
10-10-2006 19:32:30
The frame of our kewanee offset disc broke today. It is the main beam frame. It appears to be some sort of cast metal but has square tubing welded to it. Has anyone any experience with something like this happening and perhaps suggested repairs
Bob
10-10-2006 21:34:10
 Re: offset disc broken frame in reply to haweater, 10-10-2006 19:32:30
If the "cast" part was factory-welded to the steel frame, MOST LIKELY, it is NOT grey cast iron, but a STEEL forging.
haweater
10-11-2006 07:28:06
 Re: offset disc broken frame in reply to Bob, 10-10-2006 21:34:10
Thanks. It does have factory welded steel to it. What sort of rod should one use to weld this?
jmixigo
10-10-2006 19:45:51
On cast metal I like the sandwich repair. Two holes on each side of the break some 1/2" thick steel bar and some of the biggest bolts I kin find.
My welding looks like where some body spilled chilli though.
