Tractor Talk Discussion Forum
Chevy 5.3 oil pressure
J Bliler
10-09-2006 19:27:12
Have a 2001 with the 5.3 motor. Just friday the oil pressure has started swinging along with the engine rpm. It is always over the 42-45-that has been the normal but now increaces with the motor rpm, now at 35-3800 rpm it is running 75 psi!!! Any ideas?????
37 chief
10-10-2006 19:34:06
 Re: Chevy 5.3 oil pressure in reply to J Bliler, 10-09-2006 19:27:12
I had a ford don't even remember the year, it blew filter housings apart. I had to change the oil pump. Stan
souNdguy
10-10-2006 07:09:06
I have to agree with Bob.. my 2000 yukon does similar. i see pressure in the 40-70 range... rpm dependent.. also.. if it's close to an oil change it swings more too.
Soundguy
Oldmax
10-10-2006 04:19:56
Sounds like you have an oil pump problem the relief valve in the oil pump is stuck . if engine was new & tight it would blow the filter off the engine . Had this to happen on 68 ford F-100 360 engine at about 60,000 Miles of course would have to be in winter with temp about 20 deg and me with no place to work inside . Had to take oil pan off not easy job laying on ground with wind blowing under truck .
jmixigo
10-09-2006 21:24:47
My 2000 truck started that at about 190,000. Now at 215,000 it ain't caused no problems that I can tell.
Bob
10-09-2006 21:00:25
Sounds just like my 2001 Yukon. And your problem is?????
