Tractor Talk Discussion Forum
Kohler engine question
Harley
10-09-2006 18:07:30
Hello, I've got a KT19S 19 hp twin cylinder Kohler on the log splitter and can't get it to fire on both cylinders. It did for awhile but not now. I changed plugs to a hotter one, gapped the points to .016, but am not getting fire out of the coil to the plugs. Any comments or suggestions would be helpful. Only got about 4 hours on the engine so don't think it would be a bad coil, but have tried about everything else. Thanks, Harley
iowa_tire_guy
10-09-2006 19:02:14
 Re: Kohler engine question in reply to Harley, 10-09-2006 18:07:30
I have a Kolher 11 hp single cylinder on an air compessior and it would fire hot sometimes, weak sometimes and then not at all sometimes. Turned out to be the coil itself. Found it out by elimination.
IH2444
10-09-2006 18:50:25
you can probably download a nice service manual from Kohlerengines.com
I got one for my K301 there.
Turke Bros. Farms
10-09-2006 18:11:58
look for a bad plug wire. Is it a Huskee? my dad had one from Tractor Supply and did somthing similar, but it was the cut-off switctch was bad.
Harley
10-09-2006 18:18:54
 Re: Kohler engine question in reply to Turke Bros. Farms, 10-09-2006 18:11:58
Thanks, I'll check that out too.
