Tractor Talk Discussion Forum
The value of a JD 1010 ????
TLKIII
10-09-2006 17:32:51
I am looking at a JD 1010 orchard w/loader and a 4 ft bush hog. I know it's a gas bunner and the bush hog is not a JD. I am having a hard time finding the "Bue Book" value any info would help.
buickanddeere
10-09-2006 20:01:28
 Re: The value of a JD 1010 ???? in reply to TLKIII, 10-09-2006 17:32:51
Serial numbers 31,001 and higher are better. Serial numbers above 43,001 are updated even more and have a high pressure hydraulic system. In good tune the gasser is fine. Add a pertonix points replacement modual, gap the plugs 50 thou,lean the carb some and run a 195F thermostat. Make certain neither the aircleaner mesh or muffler is plugged.
jjamna
10-09-2006 17:43:26
Most 1010 are going from 3 to 6 thousand depending on the shape. However if it is for sure an orchard model you might want to grab it .According to 2cyl magazine there were only 63 gas models built.
Thats my two cents worth anyway
Good luck
Jeff
