Tractor Talk Discussion Forum
WD Antifreeze
MN Bob
10-08-2006 07:51:55
Morning all; I put just water in the WD when I replaced the pump and hose's this summer so now its time to drain it and winterize. Books at the farm and I want to take the anti-freeze with me. How many gallons do I need? Thanks, Bob
R. Freshour
10-08-2006 08:04:29
 Re: WD Antifreeze in reply to MN Bob, 10-08-2006 07:51:55
My WD45 holds a little over 3 gallons (book says 3 1/8) of coolant so I would get 2 gals.
MN Bob
10-08-2006 08:11:30
 Re: WD Antifreeze in reply to R. Freshour, 10-08-2006 08:04:29
Thanks; Seems like every year I have a bit left over and wind up disposing of it at the re-cycle center. Dont like to mix and dont trust "old" antifreeze. Try to replace every third year. Used to use supplements to replace the rust preventive but just change out now. Bob
Bus Driver
10-08-2006 08:22:56
 Re: WD Antifreeze in reply to MN Bob, 10-08-2006 08:11:30
I see no reason at all to dispose of mixed, but unused, antifreeze. I premix all mine to 50-50 and then use it as needed. Beware when purchasing, much of the antifreeze offered today is already premixed and further dilution decreases the protection.
MN Bob
10-08-2006 14:31:47
 Re: WD Antifreeze in reply to Bus Driver, 10-08-2006 08:22:56
Bus Driver; It has been my understanding that "old" anti-freeze looses its abiltiy to prevent rusting. It may still prevent the freeze but still allow cylinder walls to be eaten through. (some engines) Is this a myth?? Bob
JR-KY
10-08-2006 14:49:34
 Re: WD Antifreeze in reply to MN Bob, 10-08-2006 14:31:47
third party image
This 1938 Case had ant freeze put in it in 1972 never been changed since and is still good...
MN Bob
10-09-2006 04:28:14
 Re: WD Antifreeze in reply to JR-KY, 10-08-2006 14:49:34
Nice looking Case. Did the plow come out with that color combination? Neat looking setup anywy. I have a 48 Case D that has a bad cylinder and needs to be given the whole treatment. 4 Years now and I still havent got to it. Bob
