Tractor Talk Discussion Forum
case 444 low gear not working
coalcracker
10-07-2006 16:10:39
Need help - low gear stoped working got it back to garage in high gear. the rear has crack in it. what would cause low gear to stop working? any idea - should I get a another rear, could it be the hydo cylinder, or the hydro control valve? I spent $800 on at local dealer to replace the PTO with a new PTO kit and I want to save $$$ on this repair if I can find used parts to fix hydro drive.
john-mi
10-07-2006 18:24:30
 Re: case 444 low gear not working in reply to coalcracker, 10-07-2006 16:10:39
This is quite common on Case Lawn Tractors. The bolts that hold the ring gear shear off and go around and crack the bottom of the Case. There are upgrade bolts available. If you go to Yahoo groups and join Case garden Tractor group there archives have a lot of imformation about this. HTH. John
