Tractor Talk Discussion Forum
Engine Blow by through vent pipe
ron corkum
10-05-2006 07:49:00
I have vent pipe blow by in my 3cy diesel JD tractor. What could be the cause,head gasket or cylinder problems?
Leland
10-05-2006 11:26:51
 Re: Engine Blow by through vent pipe in reply to ron corkum, 10-05-2006 07:49:00
how much oil are you using ?
Ron Corkum
10-05-2006 15:23:15
 Re: Engine Blow by through vent pipe in reply to Leland, 10-05-2006 11:26:51
It has not been using much oil up until now but the last time I used it there was wvidence of antifreeze on the right side of the engine although the oil itself seems clean.
Leland
10-05-2006 19:07:03
 Re: Engine Blow by through vent pipe in reply to Ron Corkum, 10-05-2006 15:23:15
may need a head gasket this could cause the sudden extra blow by .
Ron corkum
10-07-2006 09:59:50
 Re: Engine Blow by through vent pipe in reply to Leland, 10-05-2006 19:07:03
Tkank you to everyone that posted a response to my quetion.
Very helpful!
b woodworth
10-05-2006 08:43:23
check values and head gasket or the bugs will be mad at you
Allan In NE
10-05-2006 08:02:45
Ron,
Is it foggin' the mosquitoes? If so, it has a hole in a piston.
Otherwise, blow-by on an older diesel is totally normal. Put a brand spankin' new engine in it and it will still have blowby.
It is how the engine breathes.
Allan
