Tractor Talk Discussion Forum
Farm Truck
MikeNY
10-04-2006 20:58:43
Hi I have a nissian farm truck in the 80s 4 cyinder with 2 sparkplugs in each cyinder not road legal and the other day it quit on me lost spark I replaced everything in the dispter check whats fuse are left and dispter does turn over what else could it be I changed the coils but still nothing please help I use this truck everyday
MikeNY
10-05-2006 21:02:34
 Re: Farm Truck in reply to MikeNY, 10-04-2006 20:58:43
Thanks to everyone I will try does things Thanks again
Nolan
10-05-2006 05:47:24
Use a meter and check for the 12 volts at the coil. If you don't have it, work up the line until you find it and fix the break.
Your truck should have a hall effect sensor in the distributor for electronic ignition, with a module on the fender or on the coil. Check these both for proper signal and lose/dirty connectors. Check the ground on the module.
fred kobs
10-05-2006 05:30:04
i had one of those. check your rotor for the set screw vibrated loose. fred
MeAnthony
10-05-2006 04:26:24
Can you, temporary-like, run a hot wire to the coil + terminal? That should bypass the ignition switch portion of the circuit. I should say that will bypass the 'run' position of the ignition switch. You'll still have to turn the key all the way for cranking power. Unless the ignition switch is bad/dead completely. Then you have to jumper the starter solenoid. I know it works well on the older Chrysler vehicles for diagnostic purposes, but I'm no pro with these Jap ones.
Good luck,
Anthony
Bryan in Iowa
10-05-2006 06:28:59
 Re: Farm Truck in reply to MeAnthony, 10-05-2006 04:26:24
just a note to possibly save from havign to spend extra money .Jumper wires and electronic ignition do not mix .Unless you know exactly what and why you are jumping . Good way to fry and otherwise good module /coil / or pick up coil . See if you have voltage on + sid eof coil with side test light while cranking .If so check neg side while cranking shoudl have pulsing light .If no pulse possible hall effect switch in dist. or module . Some of these module /coil /ignitor s are very high $$$$ I have adapted Gm module to some of these and work fine $18 verse $400 saaved big time there
Bob
10-04-2006 21:44:09
Have you checked to see if the distributor shaft
is turning while the engine is cranking over?
I don't know what engine you have, but timing belts and chains that break are common in these little Ornamental units. Then, the camshaft and distributor no longer rotate, and the valves often get up close and personal with the pistons.
If this is NOT the problem, some of these little outfits had really crappy ignition switches that can fail, and not power up the ignition.
MikeNY
10-04-2006 21:48:43
 Re: Farm Truck in reply to Bob, 10-04-2006 21:44:09
Hi Bob the distributor shaft does move could it still be the belts and chain? Thanks
Bob
10-04-2006 22:34:18
 Re: Farm Truck in reply to MikeNY, 10-04-2006 21:48:43
If the timing belt or chain is turning the distributor, you would have spark, even though the timing COULD be "off", if something had "jumped time".
Since you say you have NO spark there must be something else wrong. What year? What engine?
