Tractor Talk Discussion Forum
1963 2000 ford rear main seal
brandon l
10-02-2006 19:40:50
what do I have to do to get to the rear main seal to change it
Leland
10-04-2006 21:52:36
 Re: 1963 2000 ford rear main seal in reply to brandon l, 10-02-2006 19:40:50
If it's on the engine 1st you need to split the tractor 2nd remove clutch and flywheel then you can get to seal while you have it split I would replace the freeze plugs on back of block while your at it I have saw several leak .
