Tractor Talk Discussion Forum
Lingering fuel problems
Dug
10-01-2006 07:46:25
Still haven't solved the fuel problems on my JD F935, diesel 22 hp. After bleeding the system, it will run fine for a few minutes, then starts taking air in the fuel system. Already changed the lines (didn't change the dip lines in the fuel tanks), pressure tested system with a bicycle pump and soapy water, didn't find any leaks...I hooked on the line entering the fuel pump.
The fuel bowl is not filling with fuel, only about 1/3 fuel, the rest is air.
Have had several good suggestions to previous questions on this subject and I appreciate the responses. Any other suggestions before I contribute to the financial well being of my local JD dealership?
Dug
McRay
10-01-2006 15:27:44
 Re: Lingering fuel problems in reply to Dug, 10-01-2006 07:46:25
Check filter in fuel tank could be partly stop up
