Tractor Talk Discussion Forum
O/T - Water-proofing a tool box
farmallman
09-30-2006 17:23:45
On the back of by truck, I have a Delta tool box. It came with the truck so i never had a choice on style. Anyway, it gets water in it when it rains. Now I thought it shouldbe water proof. Does anybody know of any common spots where it could be leaking? The seal around it looks to be ok so i dont know where else to look. Thanks
Ryan - WI
10-01-2006 09:39:28
 Re: O/T - Water-proofing a tool box in reply to farmallman, 09-30-2006 17:23:45
I have to disagree a bit. I have a Delta that is the structutral plastic version. It has two doors and in the 3 years I have owned it it hasn't leaked a drop. However, on this version the lids come down much farther over the edge than on the metal models.
Dug
10-01-2006 07:56:46
Like Rusty said, two lids will leak. I have a single lid that came with my pick-it-up truck and it stays dry.
thurlow
10-01-2006 06:57:16
Does it have pipe running around the perimeter of the lid? Loosen the bolts holding it (pipe) down and put a dab of silicone around each one.
RustyFarmall
10-01-2006 04:59:59
I assume the tool box is the style with two lids? If so, I have never seen one of those that did not leak except when brand new. The style with just one lid is a much better design.
UncleTom
09-30-2006 17:45:15
Does the lid latch tight up against the seal? The latch can be adjusted to shut tighter up against the seal.
farmallman
09-30-2006 17:47:02
 Re: O/T - Water-proofing a tool box in reply to UncleTom, 09-30-2006 17:45:15
The seal is on the lid. And I didn't know the latch is adjustable. I'll have to look at that. Thanks
504-1
09-30-2006 21:35:03
 Re: O/T - Water-proofing a tool box in reply to farmallman, 09-30-2006 17:47:02
Some of them will leak water through the hinge.
