Tractor Talk Discussion Forum
John deere 14T baler help needed
chubbygumby
09-22-2006 13:05:08
hey my 14t bales just fine but then it will cycle the needles several times in a row making one heck of a knot! Can anyone tell me what I am doing wrong.
Thanks!
wayne tatro
06-09-2007 17:40:11
 Re: John deere 14T baler help needed in reply to chubbygumby, 09-22-2006 13:05:08
my 14t baler has been working fine then all at once stop tieing i know the knotters are not bad or it would have missed some but it did not has been going good then it ties one end but not catchting the other end i know its just an ajustment but am lost as to what to do any ideas thanks
`Bernie in MA
09-22-2006 17:05:38
I had similar trouble once, would make a regular bale and then cycle again making a bale about 6" long. Solved it by tightening the brake.
Tx Jim
09-22-2006 15:54:04
As stated by Kelly your measuring arm is for some reason is not returning to the adjustable stop. Have you done any adjustments to the measuring(star) wheel lately? Check the bolt and bushing for rust that attaches measuring arm to trip mechanism! Is flywheel side tire over-inflated? Tx Jim
Kelly Campbell
09-22-2006 13:46:04
Check the knotter trip arm assembly, it may be loose or your break might be miss adjusted...if possible get someone to drive while you walk behind and watch to see whats going on...I don't know about JD equip, but on Masseys there is a roller where the trip arm rides, and of course there is an adjustment for this as well...It might be the case that your knotter trip arm may not be falling back down all the way...I had this problem earlier this year and it cost me two billhooks, knives, gears etc....basically new knotters..... :(
Good luck, I'm sure more will chime in here
