Tractor Talk Discussion Forum
OT - Electric cattle fence question
CB in central N
09-22-2006 07:20:39
Greetings.
I have about 20 acres fenced in (so far) for beef pasture with high-tensile woven wire fence which is NOT electrified. The 20 acres are further subdivided with permanent woven fence lines. I did not really want to electrify it except now I want to be able to further subdivide the areas for more intensive grazing.
Here is the question: is there a way to string up temporary electric lines which are easily movable without having to electrify the whole perimeter? Traditionally one would simply take power off the perimeter wire but I"d rather not have to do that.
I"ve also seen some folks actually power their energizers with car batteries - I would think the batteries would go dead fairly soon.
Thanks in advance for all replies.
Larry NE IL
09-22-2006 10:23:59
 Re: OT - Electric cattle fence question in reply to CB in central NY, 09-22-2006 07:20:39
Why don't you string one wire around the top of your existing fence? That won't take that long, then you can tie in anywhere and the top wire will save the woven fence.
Larry NE IL
Larry NE IL
09-22-2006 10:15:12
Larry NE IL
Larry NE IL
09-22-2006 10:14:38
Larry NE IL
Luke S
09-22-2006 09:41:26
My cows will destroy woven wire fence if it does not have an electrified smooth wire on top of it. Take that for what it is worth?
nballen
09-22-2006 07:50:52
Depends on your layout...
If you run long narrow grazing areas, you could run an alley way along one end, then electrify only the dividers and the alley way. You would need to electrify part way down one side of the perimeter in order to have "hot" wire to hook you gate to.
I can try to make a picture if you like, or shoot me an e-mail.
Allan In NE
09-22-2006 07:31:48
Oh heck yeah,
Us irrigated folks have done this a lot; up to 200 acres at a pop (up or down) in about 3 hours with a good wire winder.
I always used barbed or at least a heavy gauge wire and a darned good fence stretcher. Wood posts on the corners only and the small 3/8" steel posts every twenty five steps or so in between.
A good car battery would probably last darned near a year. Used to use those little dry cells and they would go all summer. :>)
You can configure it any way ya want as long as you don't short to ground.
Allan
Drill
09-22-2006 07:29:39
You can get fence energizers that are solar powered. It has its own battery pack with a small solar panel to recharge it during the day, and it runs on the battery at night.
I use a 12 volt energizer with a deep cycle battery, it lasts for about four months between charges.
mtncows
09-22-2006 07:28:42
Yes,you can do a tempory fence with a few simple items.You will need a 400m roll of poly wire,enough fiberglass rods or step-in posts,several corner insulators, a ground rod,and a few feet of insulated copper wire.Portable chargers either of the solar type or 12v battery powered will work well.PLan on recharging car battery every 3 wks or so.
TimS
09-22-2006 09:08:18
 Re: OT - Electric cattle fence question in reply to mtncows, 09-22-2006 07:28:42
How many strands on your non electric high tensile?
I hope it's 6 or so, if its only 4 strand I have seen cattle walk thru (break wires, you name it) non electric high tensile fence.
I personally won't run high tensile non electrified.
