Tractor Talk Discussion Forum
Hard to get out of gear
williamf
09-20-2006 10:37:56
I asked this first over on the Ford Board, but no one seems to have any ideas. Thought I'd try a wider panel.
I've got a Ford 3500D TLB, manual transmission, two forward, two reverse and Hi-Lo Range.
Sometimes when I get to the end of a hard push with the front end loader it's hard to get the shifter to pull the transmission out of gear, as if the gears are in a bind. Usually if I lift the loader and move forward a little and roll back it takes the strain off. If I force it out without moving first the machine will roll a little as if the gears had been holding it back. This has been going on for a good while, and I'm not sure that it's not gradually happening more often. Any ideas?
Thanks, Wm
alg
09-20-2006 12:13:42
 Re: Hard to get out of gear in reply to williamf, 09-20-2006 10:37:56
Had the same problem with my 62 4000.Ended up being worn bearings in the tranny.Had to tear down and replace.
williamf
09-20-2006 14:09:31
 Re: Hard to get out of gear in reply to alg, 09-20-2006 12:13:42
OOF!
I'll hope that it's the clutch adjustment for now.
I should have an idea after tomorrow. "All the bearings" (phrase the service manager at Fairfield Tractor used) were replaced twelve? years ago when I took it in for a bad rear main oil seal and they found the transmission full of water. I'm hoping they wouldn't have gone south yet.
Hoping.
Thanks, Wm
RustyFarmall
09-20-2006 10:46:23
I know next to nothing about your Ford, but what you are describing sounds like a classic example of a clutch that is in need of adjustments. Get out your manuals and follow the procedure.
willaimf
09-20-2006 11:27:25
 Re: Hard to get out of gear in reply to RustyFarmall, 09-20-2006 10:46:23
So if the book says the only adjustment is the free travel and it's supposed to be one and a half inches and I measure it and it's two and a quarter inches that maybe the pedal can't move far enough to make the clutch release completely?
DOH!!!
Ok, sounds reasonable. I'll give it a shot.
Thanks,
Wm
