Tractor Talk Discussion Forum
Ford 3600 losing power
Kirk Grau
09-19-2006 10:06:02
Thanks in advance for any and all help.
My 3600 w/ FEL has lost some power (quite a bit) suddenly. Used the tractor 2 weeks ago and it was fine, but went out last weekend and had reduced power.
I recently changed air and fuel filters so I would not expect that to be an issue. Tractor starts well and sounds OK at slow idle, maybe has a little extra "puff" sound but only recognizable to me since I use it. Revs up to mid range, but at that point I can see that more exhaust is leaving than usual because the cap is standing wide open. As I continue to increase throttle it will not run any faster. Power is reduced to point it will barely haul a round bail up a slight incline, let alone the tractor by itself.
What order to I need to be looking at things. My thoughts include fuel flow, possibly injectors, and maybe timing. Also wondering (because of the increased exhaust flow) if a valve could be stuck open causing a cylinder to act more like a compressor.
Thanks Again,
Kirk
Tx Jim
09-20-2006 03:12:00
 Re: Ford 3600 losing power in reply to Kirk Grau, 09-19-2006 10:06:02
If it has a rotary inj.pump check fitting that return line connects and fuel return line for blockage along with fuel flow from tank. Tx Jim
jiskies
09-19-2006 18:53:03
i'd check the fuel supply also...have a 4000 which seems fine until under a load or full power then seems like it dies. blow out the fuel tank and she's fine.
jeff
arlobenn
09-19-2006 17:28:55
Make sure you have the right air filter. We had a 7600 one time with the right Wix filter that had the same problem. Replaced it with a Ford filter, no more problem.
Kirk Grau
09-19-2006 14:23:40
I will add that the service I was doing was more than a month ago. I will go back and double check, but am not expecting to find much.
Thanks,
Kirk
jmixigo
09-19-2006 11:48:18
I would start where I left off. Make sure that it ain't sucking air around those fresh fuel filters. Then recheck ever thing I did even if I was sure I'd done it right. If it ain't getting air through them fresh air filters it won't run right either.
Usually when I service one and of a sudden it starts running bad it's cause I "shot myself in the foot".
USUALLY when one develops a problem like that it's not timeing, valves, whatever but restricted air or fuel supply.
And I been wrong before.
