Tractor Talk Discussion Forum
3 point adjustment
nboost
09-17-2006 17:19:32
Hi all. I am new to tractors. I just bought my first one. It is a MF-35. It runs good and should work perfect for what I need. My question is on the 3 point lift. There is a adjustment on the top arm and one on the right lift arm. What are these for exactly. Thanks I am a rookie here.
TomTX
09-18-2006 05:59:17
 Re: 3 point adjustment in reply to nboost, 09-17-2006 17:19:32
As a start, you need to buy an Operator Manual,from your MF dealer. If you intend to do your own repairs, then you need to also get a Repair Manual, and a Parts Manual; also from your dealer. Tom
amo
09-17-2006 17:31:59
THE RIGHT ARM WILL ADJUST THE LEVEL OF THE IMPLEMENT BETWEEN THE 2 ARMS AS WITH A MOWER AND THE TOP ARM WILL ADJUST THE LEVEL FROM BACK TO FRONT AS ON A MOWER.
MikeinKy
09-17-2006 17:28:10
The left arm adjustment, is to level whatever you have hitched to it, such as a grader blade, so that it grades level,or to level the plows so that you have a level furrow. The center link is pretty much the same, you need the plow to be level fore and aft. Or for a mower or other equipment to run the way it was meant to.
