Tractor Talk Discussion Forum
530 case fuel pump gear
Mike Veen
09-16-2006 18:01:34
On the 1965 case 188 diesel you have the gear and shaft for the fuel pump timing.They in turn have those cursed little cup seals on the shaft,One seal faces backwards the other is opposite.How do you keep that bloody little seal from folding back on its selve.ahhhhh!!!There must be some niffy trick unknown to me.
Dale B
09-16-2006 18:13:16
 Re: 530 case fuel pump gear in reply to Mike Veen, 09-16-2006 18:01:34
Thats it !! I work for Case and we use white grease, but its the same thing. Carefully tuck the seal into the pump, and push it in..... .
chvet73
09-16-2006 18:04:07
Vaseline
Mike Veen
09-16-2006 18:40:22
 Re: 530 case fuel pump gear in reply to chvet73, 09-16-2006 18:04:07
You make it sound so dirty.Thanks I'll try it.
