Tractor Talk Discussion Forum
TO30- Hydrolic will not work, has all new parts.
5.0 kid
09-15-2006 17:12:43
TO30, Hydrolic wont work. Have replaced all parts. Does not respond at all. Give me any advice you may have about this. Thanks John
Midwest redneck
09-15-2006 18:46:53
 Re: TO30- Hydrolic will not work, has all new part in reply to 5.0 kid, 09-15-2006 17:12:43
Is a valve not functioning, dumping pressure? Do you hear fluid flowing through the valves? Check fluid level? Pump inlet blocked, dirt, or something else.? Cylinders bound up? Lever stuck for valve movement? Try these out.
jmixigo
09-15-2006 17:44:23
Start with the basics.
PTO engaged?
Hydraulic level up?
Pump bled of air?
Drive gear engageing PTO shaft?
Internal linkage all hooked up proper?
If all these are yes then it oughta do SOMETHING.
