Tractor Talk Discussion Forum
Oliver driver line noise
LBouldin
09-11-2006 18:36:06
When you let the clutch out there is a howling noise till the tractor is moving clutch all the way out then it stops. Like an unlubricated pilot bearing or a bushing.
vally farm
09-11-2006 19:20:27
 Re: Oliver driver line noise in reply to LBouldin, 09-11-2006 18:36:06
We get the same thing on our 1600. Look underneath to see if you have a double roller chain connecting the clutch shaft. If you do, and it is loose, that may be your problem. We had that growling untill that chain broke, and after I replaced it the noise went away. Shifting was also hard to get out of gear and that cleared up also. Don't know why, but it did. Hope this helps, Mike
Earl Ohl
09-11-2006 18:50:40
Your clutch release bearing may be in need of grease or it is worn out.
Matt Kane
09-11-2006 18:48:32
You might want to try this in the Oliver Forum also.
LBouldin
09-11-2006 18:38:41
This is an oliver 77 I forgot to put that in.
