Tractor Talk Discussion Forum
case 411b
doug everard
09-10-2006 06:17:15
hi, i just purchased a case 411b, runs very
good and strong, no smoke, no noises, no leaks. but two problems, the pto does not shut off,
or i might not know how it works? also, i cant
seem to figure out the shifting, or something
is not functioning? i start the tractor in gear
but can not shift it into another while moving,
to much grinding for me? help
Shovelman
09-10-2006 18:16:53
 Re: case 411b in reply to doug everard, 09-10-2006 06:17:15
Doug,
There is a brake on the PTO. Try pushing down on the PTO lever and it should stop. If it doesn't, it may require adjustment.
If your tractor is equipped with the Case-O-Matic drive, it will not shift well, especially when cold. Start off in gear, throttle up until the tractor starts moving, then pull the lever downward on the RH side of the steering wheel to shift the converter into direct.
Usually, I only shift the main transmission on my 411B at a dead stop. It takes a little getting used to.
Good luck,
Scott
Coloken
09-10-2006 06:35:22
Older tractors with gear boxes do not "shift from one gear to another". You stop, pick the gear you want and then go.
