Tractor Talk Discussion Forum
Old Farmall H
ZachOH
09-09-2006 12:30:21
I've got an H that whenever I try and start it, it turns over but it won't fire. It has been sitting for a while. I drained the old gas and put fresh in there. Any other suggestions on gettin her going. Thanks
Turke Bros. Farms
09-09-2006 13:38:22
 Re: Old Farmall H in reply to ZachOH, 09-09-2006 12:30:21
Got spark?, Check your points probably dirty if its been sitting a while, pull out a spark plug see if its wet or smells like gas. If you got gas, spark and compression, should start. Unless its out of time.
old
09-09-2006 13:38:04
Check/cleaner or replace the points. But of course check for a good spark first, I'll also bet you don't hvae a good blue spark from the points correding from sitting
