Tractor Talk Discussion Forum
444 international gas tractor
James Hogan
09-08-2006 12:23:24
My dad owns this tractor and everytime we use it it will quit running when it gets hot. Any suggestions on resolving this problem?
mowr
09-08-2006 19:01:02
 Re: 444 international gas tractor in reply to James Hogan, 09-08-2006 12:23:24
If the original, vented gas cap has been replaced with a non-vented cap, such as modern cars use, that could certainly cause the problem you describe, or worse. Causes pressure build-up (burst/gas-spray hazard) or vacuum buildup (no fuel to carb).
old
09-08-2006 12:30:09
Go out and run it till it stops. Then pull the center cap wire from the cap and check for spark. If you have no spark then your coil is probably going bad.
LD5030
09-08-2006 12:29:50
Could be the coil. It may short when it get hot after running for a while. I"d start there if you think it may be spark related. jim
