Tractor Talk Discussion Forum
Late model Perkins Question. Any Perkins gurus?
lightningale
09-07-2006 16:03:20
I recently aquired a Scat Trak with a bad motor. It has a replacement late model(2003) 400 series 2.2 liter Perkins. Apparently, this motor was run out of oil. This particular motor does not use standard main bearing caps to secure the crank in the block, but rather has "bearing carriers" that clamp around the journals of the crank and then it is installed into the block in similar fashion to a camshaft. Of all of the Internet parts sources, I seem not to see anything listed on this motor. question 1) are just the carriers available as a kit with bearings?
Question 2) the crank appears to be able to be saved by turning journals(minor scoring and little wear)DO they turn these cranks?
question 3) (The obvious one) if a complete crank kit is availalbe who can send me a name of a source? THANKS PEOPLE, Nightningale!
River bottom farmer
09-07-2006 18:21:19
 Re: Late model Perkins Question. Any Perkins gurus in reply to lightningale, 09-07-2006 16:03:20
Nightingale,Not fimiliar with the Skat trak skid loaders.Ive seen a few but never worked on one.The New holland Lx 565 and the newer version LS 160 both use a 2.2 liter Perkins but it is marketed under a Japanese name.....Ishikawa Jima Shiboura..is the name.I work on alot of the new hollands were i work and i can get the model, spec., and family numbers from it but not 100 % sure they will use the same journals, bearings or crank as they are speced out for several different applications.Let me know if you want the numbers and I will get them for you...RBF
HDM
09-07-2006 18:25:24
 Re: Late model Perkins Question. Any Perkins gurus in reply to River bottom farmer, 09-07-2006 18:21:19
Hey RBF, you work on New Holland loaders?
Don't mean to jack this thread, but do you mind if I ask you some questions about my LX885 in the future?
