Tractor Talk Discussion Forum
case manual
Rick Simmons
09-06-2006 10:51:31
I just bought a case tractor and I am trying to find a manual for it. It's a 1954, Model # is VT 54, no body can come up with that modal #. Every item on the tractor starts with the VT ex. engine VT328, clutch housing VT596, rear axle housing VT590 etc. etc. If anybody can help with this I would appreciate it.
Joe (Wa)
09-06-2006 14:31:42
 Re: case manual in reply to Rick Simmons, 09-06-2006 10:51:31
Your casting nrs (except VT54) are for 1950 or later (after tractor serial nr 5458563) VA, VAC, or VAO but not VAC-14.
Just curious, on what casting pisce is the VT54?
Joe
Keith-OR
09-06-2006 13:16:48
Is this the model # off of the tag under the gages? case used an ID tag that was put on with phillip head screws. Lots of times owner removes it and fails to put it back on, and guess what, becomes lost over time.
If you can post some pictures then maybe someone can help you with the model...HTH
Keith & Shawn
mj
09-06-2006 12:40:49
third party image
The numbers cross to the CASE VA Series, click the link for more and click an image to enlarge.
Glen in TX
09-06-2006 12:27:55
Wouldn't just V be the same ? V tricycle ?
jal-SD
09-06-2006 13:02:20
 Re: case manual in reply to Glen in TX, 09-06-2006 12:27:55
No, V series is not the same as the VA series. They look somewhat similar, but share very few parts. The V series uses a flat head continental engine, VA series uses a Case designed engine with overhead valves. The numbers that he is seeing are the casting codes for the cast parts, I believe. (My $0.02 worth. jal-SD)
