Tractor Talk Discussion Forum
O/T help with 79 blazer heater core
perry in mi
09-05-2006 11:27:56
i need to change my heater core on my 1979 blazer 4x4 350c.i w/air condition. any of you know if this is going to be a pain in the A-- long time consuming job?. or are they not to bad. any tricks or short cuts will help. thanks
Moore Dirt
09-05-2006 19:21:03
 Re: O/T help with 79 blazer heater core in reply to perry in mi, 09-05-2006 11:27:56
Been there, done that on a Taurus.
Fortunately I was able to aquire the alldata process notes.
Definately a two day affair.
And the pictures of the car with the entire dash out with wires unpluged everywhere was a site to behold.
Got it back together without extra parts. And everything operational.
Whew!
Hobo,NC
09-05-2006 15:05:41
Not a bad job you will need to remove the heater box from under the dash, its not hard to git out. 4 or 5 thru bolts that go thru the fire wall.
Tim...Ok
09-05-2006 14:02:44
Once your get the nut off of that bottom stud,behind the fenderwell,throw that nut over the nearest cliff. :o)
Tim
Allan In NE
09-05-2006 12:03:53
Perry,
There're not fun to say the least. 'Bout a 5 hour job if it has air like yours.
Grease the heck out of those new core nipples and the inside of the heater hoses before you put the hoses back on. Very easy to ruin a new core by breaking the solder joints.
Look on the bright side; at least you're not working on a Ford Taurus. :>)
Allan
bradk
09-05-2006 16:16:11
 Re: O/T help with 79 blazer heater core in reply to Allan In NE, 09-05-2006 12:03:53
Sounds like you did a Taurus core before Allan.10 hours right?
I think it's more fun getti'n poked in the eye with a sharp stick.Most of those Fords around here have been crushed. ~brad
perry in mi
09-05-2006 19:57:09
 Re: O/T help with 79 blazer heater core in reply to bradk, 09-05-2006 16:16:11
the heater core was'nt a bad job at all. just them ones with air con can scare ya sometimes. and it seems i lost that blasted bottom corner nut. haha. that one is a bugger to get. thanks guys
