Tractor Talk Discussion Forum
Oliver 60 front rim size
Kurt Smith
09-05-2006 10:03:54
Will front rims from an Oliver 77 fit my Oiver 60 RC
Thanks
Brent A.
09-05-2006 12:53:03
 Re: Oliver 60 front rim size in reply to Kurt Smith, 09-05-2006 10:03:54
60RC front wheels have quite a bit of offset on the backside so the tires won't rub the frame. I had a hard time finding a set for my 60. As far as I know that wheel is unique to an Oliver or Cockshutt 60 RC
Dick L
09-05-2006 12:48:24
 Fit, Work, Or Bolt Up?? in reply to Kurt Smith, 09-05-2006 10:03:54
Brad is as bad as I am. I have 7 Oliver 77"s only two of them have the cast front hub, five have the stamped steel rims. The bolt pattern should be the same but the 66, 77, and 88 had 16 inch rims and the 60 has 15 inch rims. I have a 60 and a 66 sitting side by side and checked with a tape measure as close as I could and the bolt pattern seems the same.
bradk
09-05-2006 11:02:54
The 60 uses a stamped steel wheel similar to a car wheel.The 77 has a cast iron hub and the rim has no center.It bolts on toward the outside of the rim.
Earlier models may differ,but we have 6 of these,and they're all the cast hub type. ~brad
